A bright green light? Are you talking about the spark or some test light?
To answer your wire question, the orange and black wires connect the pickup coil to the module to trigger it. The black wire ensures the system gets a good engine ground thru the body of the distributor.
Judging by your description, it sounds like the pickup coil is grounding out. If there is any real continuity between the orange or purple wire of the pickup to the body of the distributor (with the module unplugged from it), the pickup coil is shorted and the system won't work.
It's not real difficult to change the pickup coil, but the cost of a decent one is potentially more than picking up a used distributor.
