| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 1989
Make: ranger
Model: stx
Engine: 2.9
Class: 4x4
Used For: everything
Rep Power: 9 ![]() iTrader: (1)
I have a 89 STX, I'm pretty sure it's a high rider. It definatly stock, and sits higher than most rangers do. It's got 3" blocks in the rear, and looks to have the drop brkts in the front. I fit 31" tires no problem. From what I've read Ford stopped putting the high rider kit in, in 88. Could mine sill be a high rider? Are canadian models different?
Tweet
#2 |
Solid Axled yo!
Year: 1999
Make: Ford
Model: Ranger XLT Sport
Engine: 2.5 (5spd)
Class: SAS 4X4
Used For: Everything and more...
Rep Power: 68 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
maybe its an early 89
thats why it has the high rider pack still
__________________
click for: Ranger Sport Honduras Level II (My D30 SAS 4WD) Mini Power Stroke (My bro's Crew Cab 4WD Ranger--Slow build) Ranger Militia Cardomain(All the trucks) |
Tweet
#3 | ||
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (13)
sure sounds high-rider. Maybe a PO grabbed the 88 parts and put them on.
__________________
Project: Hillbilly Deluxe Project: Amazing Grace Project: 12-Volt Sandwich Quote:
Quote:
HELP REPEAL OBAMACARE Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind. |
Tweet
#5 | |
Year: 1994
Make: ford
Model: ranger
Engine: 4.0
Class: 4x4
Used For: dd and playin
Rep Power: 10 ![]() ![]() iTrader: (10)
got pics of the radius arm brackets
__________________
did you get stuck in your yard with that 2wd? quoted from ozziemo27 Quote:
Tweet
#6 |
Boost Junkie
Year: 94,94,95,01
Make: All 10 are Ford
Model: Ex, Cobra, Ex, Ranger
Engine: 4.0,5.0,4BT,4.0
Class: none
Used For: Going places.
Rep Power: 44 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (3)
Ford may not have called it the high rider package in '89, they might have called it the sport rider package. What ever they called it in '89, I had one with the same lift. If you want to be sure that its factory, look at the radius arm drop brackets. If they're riveted to the frame then they're stock, if they're bolted then they may not be stock.
Tweet
#7 |
Year: 1996
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4X4
Used For: Off-road/Trail riding
Rep Power: 12 ![]() iTrader: (1)
Working at a Ford plant, since 2000, our model change for the F150 has always been right around July of the previous model year, meaning, we have been building 2010 trucks since July or August and will change to 2011 model trucks again this July. My point here is, I don't think a 2/89 is an early build date. I doubt things were any different back then. The idea behind it being, get the new model built, tested and bugs worked out before the year actually comes up. Just my 2 cents.
I had a 92 Ranger that had 3" blocks in the rear too btw. The front brackets were all riveted but the truck did seem to sit higher than most. Could have been the reg cab long bed of it but once I lifted it and put 35s on it, it was definitely taller. |
Tweet
#9 | |
Premium Member
Year: 99, 02 and 06
Make: Ford /Jeeps/Etc
Model: 99 Ranger 4.0L 2wd 33x12.5 KO tires.
Grand Cherokee 4x4 4.0L
Wrangler X 5.7 Hemi
87 Samurai 4x4
Used For: DD and trail rides
Rep Power: 28 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Quote:
Maybe some just sat a bit higher then others? The year Firestone had those recalls on their tires I put on Gooryear A/T tires from Tire Kingdom. I bought a new set of 30x10.5x15 and had plenty of room in the fender well area. Two weeks later a buddy brought over his old Jeep Wrangler wheels and tires from his rock krawler prodject he was starting and we mounted his 31x10.5 setup and they fit pretty good for no lift. That is how I got the idea to put a lift on my truck the next year and went with 33's and then two years later I added the 3" BL. One good note....Firestone sent me a check for $170.00 after I sent them my receipt for buying new tires at Tire Kingdom. At least I got something back. Straycat
__________________
Straycat 99 Ranger XLT 4 door Supercab lifted 2wd 33x12.5x15 KO's on 15x8 AR polished rims Spare 33 KO mounted flat in bed/custom bed extender |
Tweet
#10 |
Year: 2002
Make: Ford
Model: Ranger FX4
Engine: 4.0 SOHC
Class: 4X4
Used For: Daily driver, towing & off-road
Rep Power: 12 ![]() iTrader: (0)
All 4WD 89 STX Rangers had the equivalent of the high rider suspension according to the sales brochure. As mentioned before, it was called Sport Rider. I bought a new very late build 89 STX that had the factory lift and it definitely sat higher than a standard stock 4WD 89 Ranger. It was such a late build that it had some 90 Ranger parts on it. From what I understand, 89 was the last year for the factory lift on a stock Ranger.
I immediately put 31" tires on it and they fit just fine. They would rub very lightly (I think the frame but for sure not the body) when the steering was turned full lock.
__________________
2002 FX4 - 4.0 SOHC, 5 spd manual transmission & transfer case, 32" ProComp MTs, K&N air filter, Modified air box inlet, Gibson SS cat. back exhaust, Bama flash, Hidden Hitch round receiver, Rear helper air springs, electric trailer brake controller, Line-X bed liner, WAAG bar with KC lights and Wildernest shell. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
