| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
Year: 1987, for the m
Make: Ford
Model: Ranger XLT
Engine: 2.9
Class: 4x4
Used For: dumping money into the drain..
Rep Power: 10 ![]() iTrader: (0)
i have been trying to figure out the wiring on this 4.0 swap... no luck. going by what someone posted in the tech area i hooked up a red/ltgreen from the 4.o harness and a red/ltgreen from the 2.9 driverside harness. but it keeps blowing the ignition fuse. i'm at a loss right now and need some serious help please! the chiltons manual and haynes manuals suck too
Tweet
#2 |
RBV Technical Advisor
Year: 1988
Make: FORD
Model: RANGERISH SORT OF THING
Engine: BIGGER
Class: 4X4
Used For: EVERTHING
Rep Power: 49 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
what year sploder?
i just leave the sploder eec harness intact and power through the diode on the switch side...the color for that varies. sounds like there is a short to ground
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
Tweet
#3 |
Junior Member
Make: Ford
Model: Ranger XLT
Engine: 2.9
Class: 4x4
Its a 93. Have you done this swap? I also can't figure out how to connect my fuel pump to my power dist box. Everything came out of a running explorer
Tweet
#5 |
Year: 1987
Make: Ford
Model: RangerSTX Straight Axle
Engine: 4.0
Class: 4x4 Extreme
Used For: beatin the shit out of it
Rep Power: 11 ![]() iTrader: (0)
__________________
'87 SAS 6lug dann44's 4;88 trac-loc up front aussie in the back the body is a 87 ranger and that is about all a little this and a little that |
Tweet
#7 |
Year: 1987
Make: Ford
Engine: 4.0
Class: 4x4 Extreme
do u have testlite ? use it
__________________
Tweet
#9 |
Year: 1987
Make: Ford
Engine: 4.0
Class: 4x4 Extreme
throw the books out and start checkin wire and wire it up mybe i should stop tellin u what to do get my ass and fix mine own
__________________
Tweet
#10 |
Junior Member
Make: Ford
Model: Ranger XLT
Engine: 2.9
Class: 4x4
That was the encouragement I needed! Just finished it up. Let me know if u need help... I learned a lot.
Tweet
#11 | |
Year: 1987
Make: Ford
Engine: 4.0
Class: 4x4 Extreme
Quote:
__________________
Tweet
#12 |
Year: 88
Make: ford
Model: bronco II
(that thing)
Engine: 2.9
Class: 4x4
Used For: whatever i want Built Ford Tuff with Junk yard Stuff and a lot of trash
Rep Power: 7 ![]() iTrader: (1)
shut up rump yours is done just tuck the wires and wheel it
__________________
New Jersey where the weak are killed and eaten ![]() Everything is capable of getting stuck. If you don't get stuck,
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
