Need cable - accelerator to transmission
gdw1591
10+ Year Member
I need to replace the cable that goes from the accelerator pedal to the automatic transmission on a 88 Bronco II. I have been told that it is either a kick down cable (TV) or a overdrive cable. The casing on the cable is broken with casing wires explosed and nicks in inner cable. I have had no luck on typical sources for replacement. Any ideas?
