I just recently put a tachometer in my '92 ranger with a stick and 2.3. I wired it all up, and it wouldn't work. I looked online and seen that the green tach wire is to hook up to the black w/ yellow stripe on the DIS. Well there is a black w/ yellow stripe wire on the top and bottom plug of the DIS. Which one does it go to? I tried both and neither worked. So I pulled out a wire tester and started testing the wires on my plug modules. ( twin square modules) I found that on each of those plugs for the modules also have a black w/ yellow stripe wire in the center of the plug with a tan wire on either side of the black one. When I checked the tan wires with the tester while she was running, my tester was flashing. Black wire was just hot with no flashing. So i took the flashing to mean thats when its firing, and hooked the wire up to that. The tach now works, but is no where near accuate. It shows idle at 500, 1.4 throttle at 1000, 1/2 at 1500 and hammer down at 2100. That poor truck can be screamin....at it will not go above 2100. So I have no idea. Has anyone put a tach in this truck and know where that darn green wire is SUPPOSE to go? Thanks. I can upload a video with the truck reving and tach as it is now incase anyone would like to see what im talking about. thanks.
I have realized that with two seperate coil banks, I am only taped into one of them. By doing so would only read half of my total RPMs. That sound about right?
) Just be sure to run this stuff outside in a driveway...it smokes like you would not believe...
