Go Back   The Ranger Station Forums > TRS Photo & Video Galleries > Your Garage > Off-Road Rangers Under Construction
Notices
Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress.
View Poll Results: What design should i put on my diff cover
Blue Oval 8 100.00%
A face (gimme more specific ideas) 0 0%
Words (gimme a specific idea) 0 0%
Other (gimme a specific idea) 0 0%
Voters: 8. You may not vote on this poll
Post New Thread Reply
Thread Tools Display Modes
Old 01-10-2010, 10:25 PM   #1
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default Project: Hillbilly Deluxe
Well, unfortunately I don't at this moment have a before pic of my truck. Also don't have many pics of the work I've done so far, but I guess it might just be time to start my build thread.
I know what I want to do, but a lot of you guys have played with this stuff already and already know how some of these things will affect it better than I do, so input and opinions are welcomed.
What I started with:
1987 Ranger XLT super cab, 2.9L FM145, MS BW1350 4x4, manual hubs, vinyl 40/60 split bench.
What I have now:
M5OD, MS BW1354 4x4, one-piece drive-shaft, cloth bucket seats and center console all from a 91 Explorer (except the d-shaft), F-250 roof lights, Midland 5001z CB radio with a 3' Firestik antenna, straight pipes with K-tuned thrush glass pack, Euro style headlights.
EDIT: 2.9L with the most aggressive cam the speed density can handle, WC heads, and a set of headers.
What I want:
4.0L, 8.8 and D-35 upgrades, 4" suspension lift (looking at a rough country setup), 33x12.50x16 BFGs, either A/T of M/T, not sure yet, with 4.11 gears, looking at dual tanks, not sure yet, and a custom fabbed exhaust with dual flowmaster super 44 diamonds and outlets out the back.
For the axles, I was planning to leave the front end open, and grab a Ranger rear end that's been blown up and dump 31 spline Explorer guts in it with a selectable locker for the back. Unless I find an EB 9 inch that is.
I plan for this to be my DD, but I also don't plan to have to drive all that far to work and I don't really plan to use it for anything but driving to work and hitting some trails here and there.
So, thoughts, opinions, advice? I'll get some pics up as soon as I can get them. I also plan on making myself a custom shifter out of a 4.0 piston. I'll be sure to take some pics of that as I do it and get them in here.
Oh also, once she is all done, in the center of the tailgate's black painted section I'm going to either air brush with a stencil, or pin-stripe by hand, "Hillbilly Deluxe" in white.
__________________
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 01-16-2010, 08:15 PM   #2
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Got the piston for my custom shifter today.
You can see its dirty, and has been used, but the metal looks good, no major carbon deposits, so it shouldn't be hard to clean up.
I'll let it sit in some gas for a day or so and post a new picture after clean up. Then to get it painted up and welded at the angle I want.
__________________
Old 01-24-2010, 06:16 PM   #3
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Ok, so after letting it sit in a mix of gas, ATF, and Lucas fuel additive for about a week and then half an hour with a wire scrub brush it looks much better.
Also go it marked out where I want to get it welded in place and get the rod cut off.
Now I just need some paint and an air brush...
__________________
Old 01-26-2010, 09:05 PM   #4
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Thinkin' about these rims. Will they fit properly?
http://www.4wheelparts.com/Wheels/AT...2fPAX398589582
__________________
Old 03-11-2010, 02:57 PM   #5
Original_Ranger84
Premium Member
Original_Ranger84's Avatar
Year: 1984, 1999
Make: Ford
Model: Ranger
Engine: 2.8L, 3.0L
Class: 4x4's
Used For: Project, DD
Original_Ranger84 is a jewel in the roughOriginal_Ranger84 is a jewel in the roughOriginal_Ranger84 is a jewel in the rough
Default
Figured I'd chime in on your build thread here... You should totally get a pic of your truck up.
Sounds like what I plan to do with my 84 pretty much, except I plan to paint it eventually... get rid of the rust.
The piston shifter seems like a cool idea but it seems a little big lol.
And the the link to the rims won't fit cause its the wrong bolt pattern and they are 18's which would be dumb... but I think they do have 15x8 in a 5 on 4.5 that would work unless you wanted 18's in which case they still might...
__________________
99 Ranger DD - 3.0L, 5spd, 4x4, 4 door, step side, 31's, 4x KC driving lights.
84 Ranger Project - 2.8L, 5spd, 4x4, regular cab, long bed, 3" body lift, 31's, 4x KC long ranges, Dual CD player/Blaupunkt Speakers.
Quote:
Originally Posted by Myself View Post
"Tall Trucks, Small trucks, whos got the balls to roll with our trucks?"
Original_Ranger84 is offline   Reply With Quote
Old 03-11-2010, 03:10 PM   #6
bcost882
bcost882's Avatar
Year: 2000, 2011
Make: Ford
Model: Ranger XLT, Fiesta
Engine: 3.0L, 1.6L
Class: FX2, Tiny
Used For: Enforcing vehicular darwinism
bcost882 is on a distinguished road
Default
you should use a 7.3 powerstroke piston haha
__________________
(2000 XLT 2wd X-cab, 3in spindles, Flowmaster delta40, Explorer 8.8in w/3.73s and crap-lok, 'sploder leafs, Belltech 6400s, 31x10.5r15 Michelins)sold
I'm not afraid to beat on my junk!
Quote:
Originally Posted by Frank The Tank View Post
You havent' lived!!!! Wake up and breath the fresh air........ open your peepers and go tackle the world.
bcost882 is offline   Reply With Quote
Old 03-11-2010, 08:03 PM   #7
Robert_1967
Robert_1967's Avatar
Year: 1988/1989
Make: Ford
Model: Ranger Supercab/BroncoII
Engine: 302/2.9
Class: 2wd Street/4x4 street
Used For: Soon to be hot rod/Daily Driver
Robert_1967 has a spectacular aura aboutRobert_1967 has a spectacular aura about
Default
the next time you want to clean a part like that, get a old crockpot, fill it with antifreeze, and let it boil over night, be warn though, do this in a well ventilated place, the fumes are deadly, take the parts out while hot, and they will look new, when I was flying r/c planes, this was the best way to clean the little nitro motors before a rebuild, oh and DON'T use the crockpot for food stuff after this.
Robert
this is also a good way to get paint off of items too.
__________________
All Truths are Known upon Death.
If I can't work on my Ranger or BroncoII, I rather be fishing.
If Facebook, MySpace, and Twitter were all destroyed, 90% of teens would go insane.
Robert_1967 is offline   Reply With Quote
Old 03-11-2010, 08:24 PM   #8
PlumCrazy
Schotty Fab & Offroad
PlumCrazy's Avatar
Year: 1995
Make: Ford
Model: Ranger Super Cab XLT
Engine: 4.0
Class: 4x4
Used For: DD/Farm Truck
PlumCrazy is a jewel in the roughPlumCrazy is a jewel in the roughPlumCrazy is a jewel in the roughPlumCrazy is a jewel in the rough
Default
Thats going to be a huge shift knob. How do you plan on welding the aluminum to the wrist pin?
I used a push mower piston on my trans shifter and a chainsaw piston on my tcase. I just tapped the wrist pin hole out to except a set screw. Then I cut the wrist pin in half and cut a V in the end and stuck it into the other side of the piston to center the piston on the shifter shaft.
-PlumCrazy
__________________
-1995 Ranger 4.0 4x4==>Build Thread
PlumCrazy is online now   Reply With Quote
Old 03-15-2010, 12:08 PM   #9
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
It is a big shifter, but it cleaned up really nice. I got a guy here at school in the manufacturing or construction (don't remember which) program to weld it up for me in his welding class. The weld doesn't look to pretty, but you won't really be able to see it once it's in.
Those rims do come in a 16x8 5 on 4.5, that was just the wrong link.
I'm not quite sure how I'm gonna attach the piston to the lever.
Might be getting me some nice 3.27 axles in a few weeks here
Here is the truck as she sits now:
A nice night pic with the cab lights on:
And here is my oh-so-comfy 91 Ex front seat setup
Just gotta get the shifter bezel and center console screwed down.
one of these days she is gonna get all the dents, dings, and rust out and some new paint.
__________________
Old 03-15-2010, 01:18 PM   #10
PlumCrazy
PlumCrazy's Avatar
Year: 1995
Make: Ford
Engine: 4.0
Class: 4x4
Default
Quote:
3.27's? What gears do you have now? My truck came with 3.27's and it sucked.
-PlumCrazy
__________________
Old 03-15-2010, 04:01 PM   #11
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
I have 3.45s now. I do not plan to keep the 3.27s, one of these days (year or two out yet) I'll be getting my lift and my 33's and I'll wave my magic wrench and those 3.27s will change themselves into 4.10s.
I don't need higher rear end gears, the 4.0 tranny gives me enough trouble on the highway as it is, both with 3rd gear accel, and then the higher OD gear means that instead of cruising at 65 at 1/4 throttle it's now more like 75 or 80.
I'm more excited about actually finding a complete d-35 and 8.8 that I can afford.
__________________
Old 03-15-2010, 04:30 PM   #12
88_Eddie
Motorboater (.Y.)
Chopper Challenge Champion
88_Eddie's Avatar
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute88_Eddie has a reputation beyond repute
Default
take one of those wire wheel brushes that attaches to a drill and clean up the piston with that. i've been cleaning up the block of my 2.9 with one and it works great. cool idea for a shifter btw
__________________
BUILD THREAD<<<<<<<<<<<<<
The Tikki Torch Build Thread
1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now)
2000 Explorer 4.0 2WD DD
Everything I need to know about Islam, I learned on 9/11.
The hardest part about a zombie apocalypse will be pretending I'm not excited.
Quote:
Originally Posted by Wedding Crashers
What'd you do with them? Motorboat? You play the motorboat? You motorboatin son of a bitch! You old sailor you!
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
88_Eddie is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
