| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Hi!
I'm the owner of a 2003 Mazda b4000 I was replacing the stock exhaust system with a Magnaflow and the upstream flange on the Magnaflow cat is no match for the flange on the y-pipe collector. Both from above. ![]() The Magna flow which does not match the stock collector. ![]() and the stock flange. ![]() Both side by side. ![]() Can I replace the y-pipe with another one from another model of ranger so I could use the Magnaflow cat? What year/model of ranger would fit that application? Any ideas as to why the magnaflow does not match? The Magnaflow part # was correct for a 2003 b4000 Mazda. Has anybody ever noticed a difference between said flanges? Thanks in advance for your help. cheers ken |
Tweet
#4 |
Year: 1995
Make: Ford
Model: Ranger Splash
Engine: 4.0 V6
Class: 4x4 Off-Road
Rep Power: 13 ![]() iTrader: (4)
It looks as if you have a 98-00 flange on there (part# 23541)....definitely the wrong part number. You need part# 93170.
__________________
95 Ranger Splash, 4.0, M5OD-R1, BW1354M, D35, Exploder 8.8 31spl 4.88, No-Slip, SJ Class II 8" Lift, 3" BL, F250 Shock Towers, Bilsteins, 1pc DS, 35" BFG M/T KM2s on 15x10s... 95 Explorer, 01 ST, 03 Explorer 4.6 2V V8, 08 ST Adrenalin 4.6 3V V8 |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
