| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1988
Make: Ford
Model: bronco II
Rep Power: 13 ![]() iTrader: (9)
i need to know what gearing to run on my 302 v8 ranger. Motor has a cam, 4bbl intake and carb with headers. Running a c4 3 speed auto. I am going to be running 33-35" tires. I want the truck to go highway speeds but i dont want the motor to be maxing out at 65 mph. What gear ratio should i run? I dont want the truck to be uberly slow off the line either.
If its not possible, i may have to downsize to 31" tires. Anybody have any reccomendations? Last edited by 88mudder; 12-05-2007 at 01:59 PM. |
Tweet
#2 |
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
What RPM range is your cam in?
The way i have always heard to figure gears is you want to be at the RPM your cam "kicks" in at 55MPH. For example. If i have a cam that makes power from 2500 to 6500 RPM. I want to be in the 2500 RPM range at 55. Just my .02 though
__________________
My Website |
Tweet
#4 |
Year: 1990
Make: Ford
Model: Ranger
Class: 2WD street
Well acording to this website your cam has .220 deg. duration so your cam most likely will be for 1500 to 5000 RPM range. http://www.fordracingparts.com/parts...tKeyField=1329
__________________
My Website |
Tweet
#5 |
Junior Member
The Motorsport E303 Cam has peak torque at 2500 RPM and peak HP at 6000 RPM. It has 220 Deg. Duration at .050" lift on both the Intake and exhaust.
35" Tires yields 9 ft. of travel per revolution x 2500RPM = 22,500 ft./ min. Dividing that figure by 5280ft/ min (using 60 MPH speed producing peak torque) gives a rearend ratio of app. 4.26. Using 55 MPH at peak torque give a ratio of app. 4.65. My recommendation is using around a 4.56 . Its been a while since I calculated rearend ratios and please feel free to correct any errors my figures may have. Good luck. Hubert Last edited by Hjcraver; 12-05-2007 at 05:37 PM. |
Tweet
#6 |
Year: 1989
Make: Ranger
Model: Supercab
Rep Power: 18 ![]() ![]() iTrader: (0)
My Ranger with a Toploader 4 speed turns 2687 @ 60 mph, that's with 3.73's and 28" tires. What ever you figure, you can add a few rpms for the slippage in a C-4. Multiply the tire diameter times Pi (3.1416) to get the circumference. Then divide the circumference into 63360 (inches per mile) to get the tire revolutions per mile, that times the gear ratio gives you the rpms @ 60 MPH. To convert to other speeds, divide or multiply other speeds into 60 to get the conversion factor. Take for instance, what you'd turn at 90 mph, multiply the rpms @ 60 times 1.5. To get rpms at 30, divide by half.
Tweet
#7 |
November STOTM Winner
Year: 1983
Make: Ford
Model: Ranger
Engine: 302 C.I.D.
Class: 2wd Street
Used For: burnouts
Rep Power: 12 ![]() iTrader: (0)
you also have to take into account your torque converter stall speed.
__________________
http://www.cardomain.com/ride/2945078 1983 2wd v8 street ranger 1991 2wd D/D ranger 2011 Ford Fusion |
Tweet
#10 |
Year: 1983 2.6 and 88
Make: ford
Model: ranger 4x4 and 2 wheel
Rep Power: 0 ![]() iTrader: (0)
ok these guys with the numbers on the brain my hats off 2 u. now i have a 83 ford ranger with a 2.8 v6 and a 5 speed tranny. it has a 9 inch lift and 35x12.50s. i put 456 gears in it and it hit on the button.has all the power i need and i can pull just about any hill in 5th gear everyday driving and plenty of take off power 2. i didnt have to get it calibrated or anything. i ran side by side with a complete stock truck stock size tires and all i ran the exact speed they were going. now with your 302 and c4 set up i think 410 will be plenty. dont want to go to big cause u only have 3 gears in your tranny.
__________________
Tweet
#11 | |
Year: 1989
Make: Ranger
Model: Supercab
Quote:
With the added torque of the V8, you don't NEED the extra 2 gears. you bought the 13 speed for? )
Tweet
#12 |
Junior Member
The E303 cam is a mid-range torque/ strong top end cam and performs better above 2500 Rpm. Ford Motorsport recommends a 5 speed transmission because of the low 1st gear and number of gears. I think a stock 302 Convertor will probably bog the motor a little during takoff trying to turn those 35" Tires. The C4 is fine but I think you need a Stall of around 2500-2600 min.to match the cam. I would love to see your Ranger try to burn some rubber.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
