| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Feels good, man.
Year: 1997
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2WD Off-Road
Used For: Fishing for compliments.
Rep Power: 12 ![]() iTrader: (1)
Hey guys.
I just fit some 33x12.5-R15 TSLs on my 4x2 Ranger (well, about a month ago). I got them on the 15x10 Crager soft-blacks. I want to air them down in the mud and the snow. I have an on-board air compressor, but I don't have a spare tire. I don't do any crazy rock climbing or nothing, just mucking around in the woods. What's a good air-down pressure to run them at so I don't blow a bead out in the middle of no-where? Thanks in advance.
__________________
Has anyone really been far even as decided to use even go want to do look more like? |
Tweet
#3 |
HCT
Year: 90/91/99/04
Model: BII/Ranger
Engine: 2.9
Class: 4x4 Extreme
Used For: Da bush
Rep Power: 12 ![]() iTrader: (0)
What width rim do you have? This plays a big part in what you can air down to without blowing a bead. Also the type of terrain plays a big part. If you are going to be mutching the side of the tire along banks of earth then chances are if you are low pressure then mud and shit will get packed in there.
I run pressures of 10 front 5 rear on the rocks, 20 front 10 rear general, and as low as 5-7 front 0-2 rear for winter deep snow wheelin. My rear tires allow me to run at 0. Also I have on board air, so if I do blow a bead its as easy as setting one in the garage with your compressor. And it sounds like you also have a good OBA setup. So dick with it until you find something that feels good.
__________________
Rig: BIITR, BII frame Ranger cab, Wontons, Winches, Transfer cases, Batteries. None steet legal. D.D/Tow rig: 94 F-150, 4x4, ZF 5 speed, 300 I6 Trust me, I'm an Engineer |
Tweet
#4 |
Clean And Articulate
Year: 2008
Make: Ford
Model: Sport Trac
Engine: 4.0
Class: 4x4
Used For: Daily Driver
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Except for rock crawling, I think airing down is very overrated. Seen many more people pop a bead when wheeling than be helped by extra sidewall flex.
With 10" rims I wouldn't air down a lot, I'd say no less than 25 psi.
__________________
Steeler Nation does not have to travel. We're already there. "It is not the multitude of ale houses that occasions a general disposition toward drunkenness among the common people; but rather disposition arising from other causes necessarily gives employment to a multitude of ale houses." -- Adam Smith, 1776 |
Tweet
#5 | |
HCT
Year: 90/91/99/04
Model: BII/Ranger
Engine: 2.9
Class: 4x4 Extreme
Used For: Da bush
Quote:
Sand wheelin, snow wheelin, muddy ass logs. Airing down is you friend when wheelin. True you can get your self into trouble when airing down, but thats why you run the right equipment if you air down.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
