| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| 2WD Suspensions Stock and off-road. This is NOT a pre-runner forum. |
Thread Tools | Display Modes |
#1 |
Year: 1984
Make: Ford
Model: Ranger
Rep Power: 12 ![]() iTrader: (0)
I just picked up another Ranger ('84 2WD-2.3L 4spd).
My ? is, do 2WD trucks do decent offroad? I would like to lift it alittle (maybe 4"). And I would also like to put a locker in the rear (maybe ARB). it would be mostly driven in Fields, Trails (with some mud, small rocks) mainly really bumpy terrain. If so what type of lift should I go with? -Camburg -SkyJacker Thanks in ADVANCE!
__________________
Kenny -1984 Ford Ranger(Play Truck) -1994 Toyota 4X4(Daily Driver) |
Tweet
#2 | |
Location: People's Republic of Michiganistan, United Socialist Republic of America
Year: 99, 96
Make: Lincoln, Ford
Model: Continental, F350 CC dually
Engine: 32v DOHC 4.6L V8, powerstroke
Class: fwd, 2wd
Used For: rice killer,Because I wanted it
Rep Power: 36 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
yep. talk to tire iron
__________________
Quote:
Tweet
#3 | |
Resident Brewer
Year: 1999
Make: Ford
Model: Ranger
Engine: 2.5
Class: 2wd
Used For: Titties n beer
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
They can do pretty well, but for trails, they're at a disadvantage due to no low-range.
__________________
Quote:
Tweet
#5 |
Year: 1988
Make: Ford
Model: Ranger
good tires and good driving make all the difference in the world. it's all about momentum. i went pretty much everywhere my 4x4 buddies went and did it faster. my friends were sissies though,
a limited slip would have helped.
__________________
88 2.3t 2wd |
Tweet
#6 | |
Quote:
__________________
1990 bronco II 4.0, dana 44, 9" spool 36" swampers, soon to have a doubler. To much other junk to even list! |
Tweet
#8 |
Year: 2003
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: DD
2wd can be fun off road, alot of the terain around my house isnt real extreme and could be boring for alot of the 4wheel guys, i think its fun to push you and your truck to your limits, see what you can really make it do, and that is kindof hard when you are using 4wheel drive to go down logging trails.
i suppose since you allready got it you might as well try it , i would see what you can get it to do with out a lift and go from there
__________________
i like my trucks like i like my women... FULL OF GAS!!
Tweet
#9 |
Year: 1977
Make: Ford
Model: Pinto
Engine: 2300
Class: 4x4
Used For: Mud racing/trails
Rep Power: 15 ![]() iTrader: (1)
yeah, It really depends on where you live and what kind of offroading that you do. I have a 2wd offroad truck in the works. I need a truck that can get big air and not bend when it comes down. I can build a 2wd much lighter in the front end. I am going to get a set of paddles for out on the dunes.
I ran 2wds offroad for years. I was really amazed at what a 4wd could do when i got my first one (the mutant pony). A 2wd will never be able to go everyplace a 4wd can. They can be fun though.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder" '86 Ranger, 3.0swap,coil rear suspension"Black Frog" Last edited by Mutant Pony; 01-01-2008 at 09:58 AM. |
Tweet
#10 |
Junior Member
Year: 1984
Make: ford
Model: ranger
I take me 2wd everywhere the 4X4 guys go... including the really soupy Florida mud and the deep water. Part of it is having a light truck with a short wheel base and good approach angles. Part of it is driving experience (this is gained by A. getting stuck, and B. watching others guys get stuck). Good tires and a good rear set up with a locker are a must, and some type of lift is a good idea for clearance...The only place i have found the 2wd at a disadvantage is when you are trying to yank somebody else out, because you don't have the low range, and the truck doesn't seem to hunker down and dig the way a 4x4 in low does whe recovering...
Tweet
#11 |
Cheaf of Grammor Poleace
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Used For: Getting irritated
Rep Power: 33 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I dont get it, 2 drive tires or 4, what is better? (with lockers of course!)
Or I guess it could 1 drive tire versus 2, either way a 4x4 is better C'Mon guys, take a 2wd to moab.....I dare ya! lol
__________________
I hate all RBV's, especially the ones I own. |
Tweet
#12 |
Year: 2003
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: DD
well that is what i was getting at, a two wheel drive could not go the same places that a comparable 4x4 would go. however with a built 4x4 you probably would get bored riding over mole holes, but that same mole hole in a 2wd could be a blast and if all you have are mole holes, a two wheel drive might do you right
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
