| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 1996
1999
Make: Ford
Model: Ranger
Explorer
Rep Power: 0 ![]() iTrader: (0)
I am currently buying a 1996 Ford Ranger 4x4 3.0 160k miles with a lift with 35inch tires. I have a few questions. One how many mpg do you think i should get? I am going to hopfully get 32inch tires for DD? It needs a wheel bearing on the rf it grinds when 4wd is engaged. does this sound rite or could it be somthing else. Also is there anything else I should look for?
Thanks in advance Brian. |
Tweet
#2 | |
Motorboater (.Y.)
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
it ONLY grinds when it is in 4WD?? sounds like it could be a drvieshaft issue or in the front diff. i would think that if it were a wheel bearing it would do it in 2wd also. check for oil leaks also
__________________
BUILD THREAD<<<<<<<<<<<<< The Tikki Torch Build Thread 1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now) 2000 Explorer 4.0 2WD DD Everything I need to know about Islam, I learned on 9/11. The hardest part about a zombie apocalypse will be pretending I'm not excited. Quote:
Tweet
#3 |
Year: 1996
1999
Make: Ford
Model: Ranger
Explorer
Thanks here is what the guy said:(the wheel bearing is in the hub and its bindin when the hub is engaged) does this sound like it could be the bearing? I talked to another guy who had it before and thats what hesaid it needed.
Tweet
#4 | |
Year: 1996
Make: Ford
Model: Ranger supercab STX
Engine: 4.0
Class: 4x4
Used For: everything
Rep Power: 9 ![]() ![]() iTrader: (1)
Quote:
Tweet
#5 |
Year: 1996
Make: ford
Model: ranger xlt 4.0l v6
Engine: 4.0l
Class: 4x4
Rep Power: 9 ![]() iTrader: (2)
lol your bearing are not bad its the locking hubs that are causing that because that happens to me when the hubs did not unlock all the way!!!! try locking and unlocking the hubs and see if t goes away!!!!
__________________
CHARGE $5 FOR WHINING IN THE FORUMS ![]() ![]() ![]() Laws are only used to stop the honest person!!! If woman don't find you hansom ,then they should atleast find you handy!!!! |
Tweet
#7 |
Year: 1996
Make: ford
Engine: 4.0l
Class: 4x4
I just put the truck and in park and cycle the 4wd to 2wd until you hear the hub unlock!!
__________________
Tweet
#9 |
Year: 1996
Make: ford
Engine: 4.0l
Class: 4x4
my is the driver side tire but i think it is the hub is not locking all the way so that cause that noise!!
__________________
Tweet
#11 |
Year: 1996
Make: ford
Engine: 4.0l
Class: 4x4
i can't imagine that it wouldn't be to hard but i know you need a special socket for the nut!!!
__________________
Tweet
#12 |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD
Used For: personal
hey all i got a ? i have a 93 ranger supercab i read bout gbuys with 4wd lifted rangers swapping there 2pc drive shaft out for a 1pc to do away with the carrier bearing and vibration well mine is 2wd and slammed with a djm 4 inch flip kit and i have a 2 pc driveshaft and have the carrier bearing shim kit and all and still have vibration at about 15-20 mph my ? is can i do the 1pc shaft swap even though i am 2wd and would it be best to cut away the cross member that holds the carrier bearing or just the bracket off of the c member its self..i have 3 inch djm dream beams for the front but havent got them put on yet so yeah lol im riding bulldog style
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
