| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1989
Make: Ford
Model: F350
Engine: 420
Class: 2WD
Rep Power: 13 ![]() iTrader: (3)
I have an 89 2wd ranger. I recently put a bit of lift on it and the steering is a bit out of wack. My tie rod end are upside down compared to 4x4 resulting in lower steering linkage. My question is if it is possible and safe to just put them on top like the 4x4 is to raise the steering some. I know I 'should' get a drop pitman arm, but I would like to save some money if this is possible.
__________________
89 Longbed, reg cab, 5 spd, 2.9, 2wd, lockrite, 33's My rig is no more ![]() 87 F350, 6.9 IDI, 5 spd, 2wd, reg cab, utility bed, DRW, 4.10 LS |
Tweet
#2 |
Yeah, I built that.
Year: 1997, 1994
Make: Ford
Model: Ranger, F350
Engine: 4.0, 7.3
Class: 4x4 Extreme
Used For: Working and Wheeling
Rep Power: 10 ![]() iTrader: (28)
tie rod ends have tapered shanks. you cant flip them over because the taper on the TRE wont fit into the taper on the steering knuckle.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall. http://www.therangerstation.com/foru...ad.php?t=21890 1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now... 1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only. |
Tweet
#3 | |
Year: 1991
Make: ford
Model: ranger-needs more lift
Engine: 4-0 swap
Class: 4x4
Used For: work and play
Rep Power: 16 ![]() iTrader: (7)
you might look into using a ream from the top for 1 ton tie rods and have the larger tie rods re-threaded for your adjuster sleeves
__________________
4.10's, 33's, duff stage 3 w/4" coils, cb,cowl snorkle, homemade high clearance d-ring bumpers,bobbed bed,8.8 My bobtail beater Quote:
Tweet
#4 |
Yeah, I built that.
Year: 1997, 1994
Make: Ford
Model: Ranger, F350
Engine: 4.0, 7.3
Class: 4x4 Extreme
this is another possibility. the catch is that it would cost more than the drop pitman arm.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
