| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1996
Make: ford
Model: ranger xlt 4.0l v6
Engine: 4.0l
Class: 4x4
Rep Power: 9 ![]() iTrader: (2)
I have 96 ranger and i want to cut of the stock muffler and replace it with a flow master series 40 muffler with 2.5" inlet and 2.5" outlet and i want the exit of the exhaust to come in front of the passenger side and i was wondering has anyone every done this and does anyone have pics of it done and a parts list???
__________________
CHARGE $5 FOR WHINING IN THE FORUMS ![]() ![]() ![]() Laws are only used to stop the honest person!!! If woman don't find you hansom ,then they should atleast find you handy!!!! |
Tweet
#2 |
Year: 1984
Make: Ford
Model: RANGER
Engine: 5.7
Class: 2WD STREET
Used For: BUILDER
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
its been done, it will be loud and interior drone will be bad. but other than that it will look cool atleast.
__________________
********THE BUILD THREAD********* http://www.therangerstation.com/foru...ad.php?t=96344 1984 FORD RANGER. 350 CHEVY SWAP. GONE BUT NEVER FORGOTTEN 1990 RANGER. 302 swap in the works ![]() 2001 VeeDub jetta. 2.0 5-speed. The daily driver (for now) |
Tweet
#3 |
Junior Member
Year: 1992
Make: ford
Model: ranger
Engine: 4.0
Class: 2wd off road
Used For: hauling race bikes to the desert and desert driving
Rep Power: 8 ![]() iTrader: (0)
Baby Turbo Angeled Up, 2 1/2 90deg Over The Top Of The Frame Rail-has To Be Flatten As It Crosses Over Frame. Straight To The Side. Use A Two Piece Tube Joint At This Area Or You Will Not Be Able To Remove. Clearences Are Very Tight But It Can Be Done. Line/cut Hole In Side, Sheet Area With Alum. Muff From Auto Zone-cherry Bomb Baby Turbo And 2 2 1/2 U-bends Of Different Radius. Jegs. Looks/sounds Sweet.
Tweet
#4 | |
Year: 99/09
Make: Ford/Jeep
Model: Ranger xlt 4x4/ Wrangler Unlimited Sahara
Rep Power: 0 ![]() iTrader: (0)
Quote:
Tweet
#5 |
Year: 1996
Make: ford
Engine: 4.0l
Class: 4x4
instead of putting the exhaust under the frame and losing ground clearance so he put the exhaust over the frame between the frame and the bed!!
__________________
Tweet
#6 | |
Schotty Fab & Offroad
Year: 1995
Make: Ford
Model: Ranger Super Cab XLT
Engine: 4.0
Class: 4x4
Used For: DD/Farm Truck
Rep Power: 18 ![]() ![]() ![]() ![]() iTrader: (25)
Quote:
Having 64" springs makes it a little tighter, so you have to put outlet a little further forward than a truck with stock springs. ![]() Some older F-150's came from the factory with the exhaust exiting in front of the tire, but they changed it because the moisture and heat from the exhaust caused the wheels to corrode and the brake hardware to seize up. -plumcrazy
__________________
-1995 Ranger 4.0 4x4==>Build Thread |
Tweet
#7 |
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0 v6
Class: 4x4
Used For: Driving A to B and some mudding
What do you use for hangers for the muffler? i have dual outs so im wondering what hangers to use
Tweet
#8 |
Year: 1995
Make: Ford
Engine: 4.0
Class: 4x4
I used a Thrush Welded muffler.
Here are a couple pics of how I set mine up. ![]() Its all one peice after the cats. ![]() -plumcrazy
__________________
Tweet
#9 | |
Year: 1996
Make: ford
Engine: 4.0l
Class: 4x4
Quote:
__________________
Tweet
#10 |
Junior Member
Year: 1988
Make: Ford
Model: Ranger
Engine: 177cid
Class: 4x4
Used For: driving, hauling, towing
I thought about doing this with my 88. I have a thrush turbo sitting from my cavie that I can use. Right under the leaf like that doesnt seem like the best place to me. when you start taking weight off the leaf does it want to push it down? Im just curious? I dont take my truck "off roading" but it does see pastures and fields on the farm.
Tweet
#11 | |
Year: 1996
Make: ford
Engine: 4.0l
Class: 4x4
Quote:
__________________
Tweet
#12 |
Junior Member
Year: 1988
Make: Ford
Model: Ranger
Engine: 177cid
Class: 4x4
Ok. cool. I asked because in Plum crazy's and in your pics it looks like its almost touching the leaf. But is that when its in the air at the end of its travel?
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
