Home       Tech      Resources      Forums       Gallery
Your Fullsize Ford Truck Resource
Go Back   The Ranger Station Forums > Truck Discussions > Fullsize Trucks > Fullsize Ford Trucks
Notices
Reply
Thread Tools Display Modes
Old 10-26-2009, 01:27 PM   #1
bmxboy809
Junior Member
bmxboy809's Avatar
bmxboy809 is on a distinguished road
Exclamation Foamy Oil...Head gasket?
just this morning my F150 ran a little funny. it was shaky at idle but otherwise it seemed ok. Then when i was done with work i it died as i was backing out of my spot and wouldnt start. this truck has a history of low vacuum and lots of blow by. Oil smoke usually comes out the cam breather so i took the air box apart to check the filter to make sure it was not saturated. the filter was ok but i saw a yellow-brown sludge in the breather tube. I checked the oil filler cap and the same sludge was there too. It didnt smell much like oil so i checked the coolant and it was really really low. To me this sounds like a bad head gasket, i have to check the plugs yet but what do you think, i am not very familiar with the 351W
__________________
1986 Ranger 2WD: lowered 3"/4". 2.3 Turbo. Too manymods to list!
Lifted 1999 Jeep Wrangler
bmxboy809 is offline   Reply With Quote
Old 10-26-2009, 04:43 PM   #2
srteach
srteach's Avatar
srteach will become famous soon enoughsrteach will become famous soon enough
Default
Oil smoke from any of the upper vents indicates blow-by of the rings (usually). Low vacuum can also be a result of bad rings.
"Snot" (brown sludge) in the oil indicates water (coolant) mixed in. Possibly a blown head gasket, but possibly a cracked head. A cylinder pressure test is needed. If you have a very low pressure in one cylinder (compared to the others), that is the one with the leak.
Just so you know, these checks are general to all engines, not just to the 351W.
srteach is offline   Reply With Quote
Old 10-27-2009, 12:13 PM   #3
bmxboy809
Junior Member
bmxboy809's Avatar
Default
i knew it had pretty bad blow by but about 3 months ago the compression was good on all cylinders. i hope it is only a blown gasket
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
