Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Non-Ranger Axles
Notices
Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc.
Post New Thread Reply
Thread Tools Display Modes
Old 11-27-2007, 11:25 PM   #1
slammer67
slammer67's Avatar
Year: 1995
Make: ranger
Model: super cab
slammer67 is on a distinguished road
Send a message via ICQ to slammer67
Default U-bolts for Waggy leaf SAS
What should I use for u-bolts on my leaf sprung SAS?
I have a wagoneer front axle and I was planning on using a 2-1/2" square u-bolt set up similar to a toyota leaf setup on the drivers side and 3" round u-bolts on the pass side, I also need a set of round 3-1/8" u-bolts for the ford 9' in the rear.
Should I use 9/16" or 5/8"; Grade 5 or grade 8, plated or no?
Many suspension companys sell u-bolts that are only 1/2" threads, is that strong enough? and 1/2" u-bolt sets are pretty cheap.
but I was looking at this on ebay: http://cgi.ebay.com/ebaymotors/ws/eB...m=290183570336
they make u-bolts in custom sizes and will do a set with two u-shaped and two square for me at same price, but what size/grade should I get?
And how important do you think it is to buy new u-bolts instead of using old ones? I've used old ones on axle swaps before and never thought much of it, but I want do do this swap right.
So what are most of you using on your axle swaps?
slammer67 is offline   Reply With Quote
Old 11-28-2007, 12:11 PM   #2
metalmacguyver
Yeah, I built that.
metalmacguyver's Avatar
Year: 1997, 1994
Make: Ford
Model: Ranger, F350
Engine: 4.0, 7.3
Class: 4x4 Extreme
Used For: Working and Wheeling
metalmacguyver is on a distinguished road
Send a message via AIM to metalmacguyver
Default
there is no such thing as too strong.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall.
http://www.therangerstation.com/foru...ad.php?t=21890
1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now...
1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only.
metalmacguyver is offline   Reply With Quote
Old 11-28-2007, 01:18 PM   #3
Natedog
Year: 87
Make: Ranger
Model: SuperCab
Class: 4x4
Used For: DD & trail truck
Natedog will become famous soon enough
Default
Long as they are still good and big enough re-use them. I used 9/16 or 5/8" on my Toyota, can't remember at the moment, had a local spring shop make them while I waited. I told them the diameter, length and U or square and it took like 15 minutes. Bought nuts and washers from them too and was cheaper and I didn't have to hack a bunch of extra off the ends when I was done.
I would do the U type with the nuts up if you can. I don't usually do plated cause mine get scuffed up on the rocks fast anyways, but rustbelt I would do plated.
That auction you posted sounds good price and quality.
__________________
1987 2.9 with 1988 emissions, Ranger Supercab converted to 4x4, A4LD pos out, M5R1 IN!
Natedog is offline   Reply With Quote
Old 12-01-2007, 10:17 AM   #4
slammer67
slammer67's Avatar
Year: 1995
Make: ranger
Model: super cab
Default
How many people are running 5/8" u-bolts on their axles?
or 9/16, or 1/2"
and what about grade 5 vs grade 8-most u-bolt adds don't specify what grade, so I bet there probably not grade 8, so is grade 8 needed for u-bolts?
Old 12-06-2007, 07:50 PM   #5
madmax401
madmax401's Avatar
madmax401 is on a distinguished road
Default
check out "ruff stuff specialties." they have kits for that and are thcker than stock -heavy as hell. simple swap kits include leaf spring perches- shock mounts - u bolts and plates for 110 bux. cant beat that .
madmax401 is offline   Reply With Quote
Old 12-06-2007, 07:55 PM   #6
madmax401
madmax401's Avatar
Default
i found the link
http://www.ruffstuffspecialties.com/...nger-c-32.html tell them your from the ranger station to recieve your discount. i ordered and i like.
Old 12-07-2007, 07:42 PM   #7
slammer67
slammer67's Avatar
Year: 1995
Make: ranger
Model: super cab
Default
I bought 2 sets of 5/8's grade 8 bolts with shipping for about $65.
from ebay seller palmerspring
they were made to order and I got a set with two round and two square u-bolts for the front d44 and a set of four round for the ford 9".
thanks for the link though.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
