| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1993
Make: Ford
Model: Ranger
Rep Power: 0 ![]() iTrader: (0)
OK I've bled the brakes...put new master cylinder in. Pedal goes hard when engine not running....but when engine is running pedal goes all the way to the floor...Oh yeah 9 inch rear end...so rear abs disconnected...new brakes lines pretty much everywhere
Its a 93 Ranger I'm stumped Last edited by driveoverit; 11-27-2007 at 09:13 PM. |
Tweet
#3 |
It's only money...
Year: 1993
Make: Ford
Model: Ranger
Rep Power: 10 ![]() iTrader: (2)
Did you follow the procedure to bleed the master cylinder before you installed it?
__________________
Blue 93 Ranger 4.0L 4x4 5spd, 38.5's on 16x10's EB coils, 6" Skyjacker Leafs, Belltech 6400's, Bilstein 5150's Fullwidth D60, Lockright, 5.38's, Dedenbear C's 14BFF, 5.38's, Detroit, Disc Braked 3" B/L, Dual batteries, 9500lb winch, Bushwacker cutouts |
Tweet
#5 |
Year: 1993
Make: Ford
Model: Ranger
ok i bled the brakes again and still it goes to the floor when its running(goes hard when its off)....could it be something to do with the Rabs module??? How about bypassing it??? Does it contain a residual check valve?
Tweet
#7 |
Year: 1993
Make: Ford
Model: Ranger
i think you might be on the right track with the booster....when the truck is running and you press your foot to the floor the truck almost stalls out
Tweet
#8 |
Year: 1994,1965
Make: Ford
Model: Ranger supercab, Mustang Coupe
Engine: 4.0, 302
Rep Power: 13 ![]() iTrader: (1)
I would thoroughly inspect the booster. Leaks, hoses, check valves. I wonder if you could have got moister in there or something, or if that would even matter. WIth the truck off press the brakes and then hold them as you turn it on. It sould make the pedal eaisier to press. Thats an easy way to make sure its working. I guess its sinking to thefloor though so it must be.
Tweet
#9 |
Year: 1993
Make: Ford
Model: Ranger
i figured it out...it was the calipers hanging up on the steering knuckles....i have the chevy disc brake swap...there is a clearance issue between the two...i have since ground down the knuckle and a little bit off the caliper....
i think it was the backing plate flexing from being hung up on the knuckle therefore making the brake pedal go all the way to the floor thanks for the suggestions |
Tweet
#10 |
Logan Andrew Feb 17, 2012
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (15)
Thats the same thing that happened to me. I had accidently put in a pad wrong and it was compressing or something and causing the caliper to compress sideways.
__________________
1989 Bronco II, 2.9L, Manual Trans and T-case, Manual hubs | 2004 Tahoe Z71, 5.3L 4L60E, AutoTrac 4WD, Leather, Bose, DVD, Loaded | 2009 Silverado 2500HD Duramax/Allison Crew Cab Long Bed 5" MBRP Straight Pipe, EFI Live Tuned by Longhorn Fab Shop. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
