#1 |
I got some new meats on the way, 35x12.5R15 Trxus MT's. Stock gears in my 95 are 3.31 according to the door tag, I know with the 31" A/T's on it now she barely holds OD at 55, 35's are going to suck.
I found a guy selling some 5.13 geared axles, 8.8, D44 TTB, think that would be too low? I don't do much highway driving, I get 10 mpg right now no matter what I do. Probably go up with that gear/tire combo He's also selling a 6" lift, doesn't know what brand, when I get pics I will post them and see what you guys think. I was just going to do a body lift and hack the fenders, but a suspension lift would be ideal. |
#2 |
Holy crap Google is fast, searching for 35 tires 5.13 gears and this came up on the first page of results.
#3 |
You shoulda got a 300-6 instead of a 302, lol
__________________
"lil Blue" 2000 Ranger Supercab xlt: 3.0L, 5-spd, 2wd "S**tbrick" 1988 Bronco II Eddie Bauer: 4.0L, auto, 4x4 1989 Bronco II choptop: 2.9L, 5-spd, 4x4, 7" lift, locked f/r, 33's "Phoenix" 1986 Bronco II xl: 2.9L, auto, 4x4 (future trail toy) 1989 Ranger parts donor: 4cyl, manual trans, 4x4 |
#4 |
There's always the possibility of a 351W
![]() Will I have to do anything with my trans when I do tires and gears? I keep reading stuff on people with auto transmissions their shift points getting screwed up, I've never had an auto before so I have no idea if it's going to get screwed up. I miss my stick shift , maybe a 5 speed will be the next mod ![]() Oh yeah, my road is water proofed in front of my house. The oil pan on my truck leaks about a quart a week, if I go get these axles and lift kit one of my friends has a new oil pan for me
__________________
2004 F150 FX4, all black, brush guard, roll up tonneau cover. Last edited by milje; 10-07-2009 at 11:23 AM. |
#5 |
lol, we had somethin better than that happen to our one F-350... was dumping a couple ton of stone one day, bed went partway up then there was a pop an the bed went back down... and about 3 gallons of hydro fluid started running from under the truck... sprayed the hell out of the underside when that line blew an that stuff just does not seem to wear off like motor oil.
__________________
#6 |
Junior Member
Rep Power: 10 ![]() |
Barely holds OD at 55 now? My 94 has a 300-6, manual tranny, and 3.55 gears, and turns 31s easily. I can tow 2 horses trailered at 65 in 5th and still not have it on the floor. I still only average 10mpg, but I know it would be higher if I could figure out my engine problems.
According to a calculator, I would need 4.10s to turn similar rpms with 35s. 5.13s with 35s should only run ~750rpms higher for highway driving than your current combo, but would make a ton of difference in acceleration. |
#7 | |
Quote:
The guy should be sending me pictures tomorrow of the lift, sounds like it has Superrunner steering, will have to wait for the pictures. |
#8 |
Rep Power: 14 ![]() |
Not to bash your truck, but the 5.0L is a poor engine choice for a full size pickup. Even though it's 40 less HP at an RPM that you'll rarely use with either motor, the 4.9L makes a much better engine for normal truck use.
I'd say 5.13s are probably over kill though. I'd go with 4.56 or 4.88 at the most.
__________________
2011 Ford Ranger XLT Ext Cab 2.3L 5-spd - DD 1992 Explorer Sport 4wd 5-spd 1995 Ford F-150 Custom 4wd 4.9L ZF5 coming soon! 2005 Lincoln LS 3.0L V6 - Wife's Past: 1990 Ranger 2wd 2.3L Turbo
#9 | |
Quote:
Two guys at work have trucks I am interested in, a 78 F150 and a 77 F250. I might see what I can do moneywise, maybe pick one of them up. F250 has a Boss V-plow, would come in pretty handy since my snowblower is a pile Not sure if I should keep my 95 if I buy one of them, if I dump off my F150 (just fixed just about everything that was wrong with it, just needs an oil pan but it's not urgent, new u-joints and all new brakes and bearings in the end just got put in last weekend), it would make a good winter runner, but if I sold it she'd pretty much pay for one of the other trucks. I guess I'll have to go take a look at the other two trucks. |
#10 |
J-man HD Mech
Rep Power: 10 ![]() ![]() ![]() ![]() |
If they're in good shape (no broken teeth/bad bearings) I'd use them. It's better to be over-geared then under-geared in my opinion. The 5.0L is a windy engine much like the 5.3L in newer chevy's, they don't make much (relatively) torque down low so deeper gears will help you out even more then compared to the 300/I6 or the 351W.
If you do a 5 speed, look for a ZF tranny vs. the M5OD-R1 as it's a much beefier tranny. |
#11 |
Rep Power: 9 ![]() |
yea what ^he said...if your not worried about gas mileage its near impossible to have too much gear especially with an overdrive trans
i mean i know guys running 4.56s in mustangs with a 26 inch tire on the street so i dont think 5.13s with 35s would be bad at all....if you didnt have o/d then yea that would be a different story |
#12 |
J-man HD Mech
A lot of times underpowered (or low torque at low rpm) vehicles will benefit from lower ratios as the engine is doing less work revving at say 3k, then lugging at 2k. I get better mileage with 4.56's and 35/37's then I did with 3.73's and 33's. And yes, my speedo was corrected.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
