Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 10-03-2009, 04:05 PM   #1
MojoX
MojoX is on a distinguished road
Default 2k5 Ranger Bolt Pistons
Okay, so it wasn't my bearing. YAY. It was my brake pads. YAY.
However, I seem to have another issue.
There are two bolts that hold the caliper in place. Both bolts screw into some sort of piston. One of the pistons is frozen in place.
Now what?
MojoX is offline   Reply With Quote
Old 10-03-2009, 07:55 PM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Now you either unseize the caliper slide pin, or replace the caliper bracket and get new slide pins.
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 10-04-2009, 05:17 AM   #3
MojoX
Default
Do I just pound the Hell out of it?
Old 10-04-2009, 08:55 AM   #4
Nhaz
Nhaz's Avatar
Year: 1998 and a few
Make: Ranger+Ranger+E
Model: XLT + XL
Engine: 4.0 3.0
Class: 4x4
Used For: 2500+ kilometers a month
Nhaz is on a distinguished road
Default
sounds like its torch time. Get it really hot where the along the cast where the threads of the bolt are.
When it comes apart be sure to use antiseize compound/paste on the sliders when you put them back.
__________________
Damage to the Mercedes that cut me off. front end Gone : cost $8000+
Damage to my truck ..my tire bead. Cost. $20 to pull the tire off and reseat it. it was leaking air
Nhaz is offline   Reply With Quote
Old 10-04-2009, 10:18 AM   #5
AllanD
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
AllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to behold
Default
The calipers bolt to the Caliper pins which slide into the caliper bracket
The factory uses a scant ammount of grease and water can get
inside from wheeling... I strongly recommend that EVERYONE with
two piston calipers remove their calipers then the pins from the
brackets and coat them with a good waterproof (preferably synthetic)
grease, this will "head off" most future problems.
AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun.
AllanD is offline   Reply With Quote
Old 10-04-2009, 12:47 PM   #6
MojoX
Default
I've picked up some "gunk" and have been spraying it where it meets the housing and bashing it with a hammer every 15 minutes or so. I'll break out the torch later after the Browns lose.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
