Ok, I am by far not a audio expert so I have a question. I have 2 MTX thunder 7000 10" subs that are 8 ohms each. I want to know if i can wire those to a single channel amplifier without hurting anything. the amps is 1600watts (400 RMS) X1. it says on the specs of the amp that it is 2 ohms stable. it also says that 1600watts ACH power 400 watts X 1 @ 4 ohms RMS power. SO, can I wire both these subs to the amp? if so, how? both positives to the positive output and both negatives to the negative output? OR do I hook one of the positives to the positve, then hook the negative of that sub to the positive of the other and then the negative of the 2nd sub to the negative of the amp?? Thanks
