Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4-bangers > 4-Cylinder (2000 & Older)
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 09-27-2009, 12:46 AM   #1
flaminranger
flaminranger's Avatar
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.0
Class: 2wd street
Used For: work
flaminranger is on a distinguished road
Default 3 angle valve job?
I was wondering if anyone has had a 3 angle valve job done on a 2.3?
did it help? what were the angles ground at?also what about a back cut on the valves I heard that helps low lift numbers a lot. that would be a real big help on the low rpm out of the hole acceleration.
I ask this as my little evil brain is trying to figure out how to make this motor more efficient with out making a bunch of mods (like adding fuel injection and a turbo)so that mileage goes up cause the motor doesn't have to work so hard.
flaminranger is offline   Reply With Quote
Old 09-27-2009, 01:56 AM   #2
SMTGREG
SMTGREG's Avatar
Year: 1965
Make: MGB
Engine: 2.3 Lima
SMTGREG is on a distinguished road
Default
A three angle valve job uses 30, 45 and 60 degree cuts. As far as the valves get stainless steel valves. Manley supplies valves to Esslinger so take your choice.They are the best 2.3 valves. I installed the oversize valves 1.89 intake 1.59 exhaust in my head. Focus on the valve bowl and the short radius in the exhaust port first for porting. I recommend Lunati for a cam they will custom grind a cam or recommend one for you. Go to a 2 1/4" exhaust system. Quickest HP comes from more compression. I had my head cut .060 and added a adjustable cam pulley to reset cam timing. Advancing the cam timing will give you a little better low rpm power but never more than 6 degrees.
__________________
91 Ranger 2.3 5 speed and 3 L's (leaks,loose parts and less rust)
65 MGB with modified 2.3 203 hp
SMTGREG is offline   Reply With Quote
Old 10-05-2009, 08:19 PM   #3
scrapper
Year: 1994
Make: ford
Model: ranger
Engine: 2.3, 3.73 with 235/75/15
Class: 2WD, 3" body lift
Used For: daily driver, towing trailer
scrapper is on a distinguished road
Default
I thought that all valve jobs were ground with 3 angles? I read that in hot rod or something? Is that correct?
scrapper is offline   Reply With Quote
Old 10-08-2009, 10:47 PM   #4
flaminranger
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.0
Class: 2wd street
Used For: work
Default
Quote:
no it is not most are a single cut like 45 degrees(not sure of the angle that is just an example number)
some people mistake the margin as one of the cuts and it is not part of the valve job the valve job is on the face of the valve where it makes contact with the head.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
