- Aug 18, 2007
- New Richmond, WI
- Automatic
Hey guys, yet another issue with my '89. It won't fire at all, I got spark, and fuel. last time it did run it ran ok to start with then after a little while of driving it started to hesitate upon application of throttle. At first it was at almost 3/4 throttle then it started doing it at lower amounts and then it finally died at a light and wouldn't restart at all. I had a prior code saying it was the MAP sensor and tonight I swapped in a new one and not go. Is it possible that it threw the timing off enough that I have to re-set it? As for the 2 pumps the truck has a factory pump in the tank as well as one on the frame rail where a filter usually is and there is no filter.
Help please its drivin me crazy
