85_Ranger4x4
Wallers in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
I finally think I am ready to start a swap thread to keep my swap questions in...
Anyway, I dug up a '78 302 I am going to go check out possibly as early as tonight. Any idea what the hp should be? I know it is going to be pretty sad but I am still curious.
I have a set of '67 289 heads (condition unkown), would they help get the compression up to halfway liveable level and interchange easily since it isn't a roller? Any advantage to using the 289's exhaust manifolds too?
The 302 was in a '83 Mustang so it "should" have the dipstick in the pan.
I am going to put a 4bbl on it of some sort if it doesn't have one already, duraspark ignition (plug and play since the truck is already set up for it) and a C-4/5 mutant with the stock BW1350M transfer case.
I don't have a heated shop to work on a dead truck in, so for now the plan is to put the 8.8 in the truck this fall, so when I back it into its hole for heart surgery next spring it is already in place for driveshaft issues. The truck fills up its alloted space so I can only work on one end at a time. And then I get the engine set up how I want it during the winter.
