| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 2001
Make: Ford
Model: F-250
Engine: 7.3
Class: 4x4
Used For: Everyday use
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (8)
I know the cam syncro seems to be an issue on the 3.0's but what about in the 4.0s? Do they have the same issues? I should have asked when I had the engine apart because it would have been so easy to replace but I thought i'd ask. It's a 4.0 OHV...
Tweet
#3 |
Super Moderator
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Used For: a chicken house
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
What's a cam synchro? All I know is that if you have a SOHC 4.0, don't muck with the sprockets or you'll be really screwed.
__________________
'83 Ranger cab, '89 B2 frame, 4.0, C5, D35/8.8, 4.10s, Lockrights. '87 Chevy crew 6.2 Banks turbodiesel TH400 GearVendors 4.10 14-bolt Detroit '96 VW Passat Tdi '00 Ford E350 15-pax Powerstroke '09 Suzuki TU250X '04 Moto Guzzi Breva http://willwills.com/ |
Tweet
#4 |
Year: 2001
Make: Ford
Model: F-250
Engine: 7.3
Class: 4x4
Camshaft synchronizer (sp?). It basically replaces the distributor. It's a common item on the 3.0's. There are quite a few threads in the 3.0 section about it and i've found quite a bit of information about it on other websites. I searched the 4.0 section but turned up nothing about anyone replacing it. I was wondering if it is a common item on 4.0's too.
Here's an example:http://www.therangerstation.com/foru...ght=Cam+syncro Found this on RPS also...http://www.rangerpowersports.com/for...d.php?t=227208 Maybe we need more info on the 4.0 OHV?
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
