Wiring Help '86-'88
Ranger-Rod
15+ Year Member
1986-88 Ford Ranger Stereo Information
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Chassis
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Front Speakers 4" Dash
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Rear Speakers 5" x 7" Rear Corners
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Ground Chassis
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Very cool, thank you!
Rear speaker polarities
Could you double check these polarities for the rear speakers? My '86 Ford E&V Troubleshooting manual pretty much confirms the wire colors, but the schematics do not indicate which wires should be (-) or (+). For the front speakers, the common BK/W is used for the (-), but for the rear?? :icon_confused: In the schematics, does (-) always attach to the bottom of the speaker symbol?
I am trying to install a same year electronic radio from an Aerostar, and the wire colors are not even close. The positions on the connector plug seem to be about right though; its just that my Ranger does not have the original rear speaker wiring. Thanks for any help!
