| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Junior Member
Year: 1987, for the m
Make: Ford
Model: Ranger XLT
Engine: 2.9
Class: 4x4
Used For: dumping money into the drain..
Rep Power: 10 ![]() iTrader: (0)
My ranger runs kick ass in the first initial start up untill i drive about 15 minutes. then it feels like the timing is way off and i have no pick up. everything is up to spec as far as timing goes. i have a replaced tfi module, Coolant Temp sensor, idle air controll, TPS, MAP. so now i have a break out box and want to know if anyone has a lead as to what i should look for as far the problem goes. also no codes continuios or memory....
Tweet
#2 | |
Year: 1986
02'
Make: ford
Model: ranger
f150 fx4
Engine: 2.9 & 5.4
Class: 4x4
Used For: exercise and DD & hauling college kids stuff
Rep Power: 14 ![]() iTrader: (3)
Quote:
how about the o2 sensor??..this should kick in after being up to temp What about the catalytic converters....are they resent? or aged? is spout plug back in place? (for setting base timing) What fuel pressure after it is warm?
__________________
IMenRiched By the power of Lord Jesus ![]() 2 are willing to die for you. one is a soldier, but the 1st was Jesus Christ ~few appreciate either~ |
Tweet
#3 |
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4X4
Used For: Off road / daily driver / Haulin Dirt Bikes
once the engine warms up are you hearing any valve train noise? also, does the engine ever backfire when it is running like this?
Tweet
#4 |
Year: nada
Make: Ford
Model: 2008 F150
Engine: 2.9
Class: 2WD
Used For: teach my boys to not get rid of a Ranger.
Rep Power: 47 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Does it still run ok - no missing etc? Mine acted sort of like that - turned out to be stuck caliper pistons after I drove a while and got them heated up.
Tweet
#5 |
Junior Member
Make: Ford
Model: Ranger XLT
Engine: 2.9
Class: 4x4
o2 sensor is replaced, spout plut is in, catalytic converter is stock.. doesnt miss fire and i do hear minor valve train noise when warmed up.. and fuel pressure is good
Tweet
#6 | |
Year: 1986
02'
Make: ford
Model: ranger
f150 fx4
Engine: 2.9 & 5.4
Class: 4x4
Quote:
How new is it?? the Catalytic converter that is it might be the compression is getting weak too.
__________________
Tweet
#7 |
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9L V6
Class: 4x4
Rep Power: 0 ![]() iTrader: (0)
Mine is doing the same thing. I picked it up a week ago, and I've driven it probably 200 miles total since. I just put in a larger TB, 180 degree Tstat, and cleaned up the intakes and it helped a little bit, but I still have it occur after about 15-20 mins (though not nearly as drastic). Mine needs some exhaust work badly, the muffler and tailpipes are rusted, and I'm betting the cat and/or O2 sensor is going to be the culprit. I'm going to have them looked at/changed here in the next few weeks, I'll let you know if that solves it
Tweet
#8 | |
Year: 1988
Make: Ford
Model: Bronco II
Engine: 2.9L V6
Class: 4x4
Quote:
I hear a little valve train noise when mine warms up too, but I had a 1990 Ranger a while back that was twice as loud in the valve area, and never had a problem like this |
Tweet
#9 |
Junior Member
Make: Ford
Model: Ranger XLT
Engine: 2.9
Class: 4x4
ya i'm now thinking that i'm just going to cut out the cat.. i think thats the culprit. let me know how yours comes out
Tweet
#10 |
Year: 1990
Make: Ford
Model: Ranger Super Cab
Engine: 2.9
Class: 4x4
Used For: From Woods to Travel! and Everything in between.
This site is great! I have just installed a Remote TFI Module on the Passenger Side Inner fender of my 90 Ranger because it ran terrible after the first 15 min or so. My sons and I had trouble finding a Heatsink so I Milled one using a Briggs & Stratton 8HP Cylinder Head. Workes Great! We have some other issues we are working on but the Truck is running stronger. Infact, I have owned it for 4 years now and it has never ran so strong.
I noticed that the TFI gets extremely hot on it's own not to mention the engine heat from the Distributer Mounting. Today, my boys and I are going to get a spare heater blower fan which I will install on the HeatSink to keep it even cooler. Last edited by Nez; 09-18-2009 at 03:25 PM. Reason: Bad Picture Upload |
Tweet
#12 |
Year: 2002
Make: Ford
Model: Ranger FX-4 level 2
Engine: 4.0
Class: 4x4 Extreme
Used For: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Rep Power: 16 ![]() ![]() iTrader: (0)
That's real pretty Nez! I'm wondering why millions of others work right where Ford put em..and yours doesn't?
Big JIm |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
