| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8 |
Thread Tools | Display Modes |
#1 |
Year: 2002
Make: Ford
Model: Ranger Edge
Engine: 3.0L
Class: 2WD
Rep Power: 0 ![]() iTrader: (0)
i have a 02 ford ranger edge 2wd and i know that it has the open diff. i am trying to find a posi for it so i can get some better traction in the dirt. i really want to keep the gears i already have and just swap the open one for a posi. any help would be nice thanks
Tweet
#2 |
WRENCH WERKS
Year: 1994
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 2WD OFF ROAD
Used For: EVERYTHING A RANGER CAN DO, AND LOTS OF THINGS IT SHOULDN'T
Rep Power: 18 ![]() ![]() iTrader: (0)
what size is your axle, 7.5" or 8.8"? lock rite would be an option for the 7.5, and im sure there are more options for the 8.8 if that is what you have.
__________________
1994 Ranger 4X2 Off Road, Built Not Bought! http://www.therangerstation.com/foru...ad.php?t=37621 |
Tweet
#3 |
Year: 2002
Make: Ford
Model: Ranger Edge
Engine: 3.0L
Class: 2WD
i kno that it is the 7.5 but i was thinking that i could get a 8.8 but that might be alot of work so i was tryin to find it for the 7.5
Tweet
#4 |
Year: 97,79,00,72,71
Make: Ford
Model: Ranger, F250, F350, Mustang, Bronco
Engine: 3.0, 460, 7.3psd, 351c, 351w
Class: little bit of everything
Used For: waste all my money
Rep Power: 11 ![]() iTrader: (68)
I have a good used posi from a 7.5 that had 3.73 gears if that would work for you I'd take $50 plus shipping.
__________________
97 Ranger 3.0 5spd 1354m disc 8.8 00 F350 Dually Crewcab 4x4 7.3 6spd 79 F250 501BBF,4spd, d60, 10.25 38s 72 Mustang Mach1 351C, 4spd 71 Bronco d60, 14bt, 351efi, 4spd,203/205, 44s beadlocks plus lots more |
Tweet
#5 |
Year: 2002
Make: Ford
Model: Ranger Edge
Engine: 3.0L
Class: 2WD
is that the ring and pinion also?? what kind of posi is it?? oh and i am new on these forums so how would i pay you?? sry for all the questions.
Tweet
#6 |
Make: Ford
yea, I can give you the ring and pinion too. It is a factory trac loc. paypal is best. You would also have to pay shipping unless you plan to pick up I'm near Pittsburgh PA.
__________________
Tweet
#7 |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Rep Power: 24 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Posi a GM slang term for limited slip...
Are you looking for an LS or a locker?
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs 95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked |
Tweet
#8 |
Year: 2002
Make: Ford
Model: Ranger Edge
Engine: 3.0L
Class: 2WD
i am looking for whatever is easier and will work the best. for sand or light mud since right now i am in AZ and will be moving back to WA in DEC. the truck is also getting the prerunner treatment so i want something that will work good on the street as well.
Tweet
#9 | |
Year: 2002
Make: Ford
Model: Ranger Edge
Engine: 3.0L
Class: 2WD
Quote:
ok i will keep it mind but i am in AZ so i might try to find something closer haha thanks for the offer tho Last edited by rockstarpanda; 09-16-2009 at 11:54 PM. |
Tweet
#10 | |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Quote:
With a limited slip or any other full carrier replacement locker, you need to check the backlash at the least and actually shim it correctly if the backlash does not check out. An auto locker will never be as smooth as a limited slip or selectable locker but they aren't that bad, I used to drive 1000 miles a month in my B2 with a locker.
__________________
Tweet
#11 |
Year: 2002
Make: Ford
Model: Ranger Edge
Engine: 3.0L
Class: 2WD
do you know any good websites to get it from cuz i have ran into a couple very poor site while looking for this kind of stuff. thank you for your help!
Tweet
#12 |
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I was installing new front diff [4-10's] in my '85 b-2 and decided to make it a l/s instead of welding the spiders [ the guy at The Gear Center suggested welding as I could unlock the hubs]. It's driven on and offroad. So what I did was add an extra thrust? washer from the old diff to the new one [ large thin washer / not curved]. I did this to a 9" years ago and it worked fine for many miles, never did break any thing [ tho it did have 4 spiders , not 2].
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
