Go Back   The Ranger Station Forums > Styling & Electrical > Lighting/Illumination
Notices
Lighting/Illumination This forum is for headlamps, auxillary lighting, interior lighting, and LED conversions.
Post New Thread Reply
Thread Tools Display Modes
Old 09-12-2009, 10:55 PM   #1
That Baker Guy
That Baker Guy's Avatar
Year: 1993
Make: Ford
Model: ranger xlt limited edition
Engine: v6 3.0
Class: 2wd
Used For: what ever comes up
That Baker Guy is on a distinguished road
Default how to align headlights?
iv searched around the forums and google, but how do i align my headlights for the ranger, i just got new ones, and they are pointing at the ground and its annoying, is there anything special i should know when doing this?
__________________
build thread --> clicky
That Baker Guy is offline   Reply With Quote
Old 09-13-2009, 12:29 AM   #2
85DANGERanger
85DANGERanger's Avatar
Year: 1989
Make: Ford
Model: bronco II
Engine: 2.9
Class: 4x4
Used For: intertainment
85DANGERanger is on a distinguished road
Default
point your truck at a wall or the garage door, about 25 ft. away, and adjust them until the light on the wall is 3 1/2 to 4 foot off the ground.
__________________
1989 Bronco II, 4x4, 2in. body lift, 2.9 with crane cam, MSD igintion chip, air/fuel ratio chip, centerforce clutch, ARP bolts in motor.
85DANGERanger is offline   Reply With Quote
Old 09-13-2009, 12:50 AM   #3
baxtej44
baxtej44's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.9L
Class: 4x4
Used For: General driving
baxtej44 is on a distinguished road
Default
Quote:
is that what it is documented that it should be at?
just wondering, because I need to do the same thing.
__________________
Photobucket:
http://s629.photobucket.com/albums/uu14/baxtej44/
baxtej44 is offline   Reply With Quote
Old 09-13-2009, 01:28 AM   #4
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
No that is not the 'proper' way, but it does work.
The headlights will have numbers and letters on them.
Like H12 V6...these are used to the set the proper headlight aligning tool up, then you adjust them until the bubble levels on the tool are level, and the mirrors line up between the 2 heads. (H = horizontal, V = vertical)
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is online now   Reply With Quote
Old 09-13-2009, 03:46 AM   #5
85DANGERanger
Year: 1989
Make: Ford
Model: bronco II
Engine: 2.9
Class: 4x4
Default
this would be the proper way for sure, but rarely do people use the alignment tool. most shops dont even have it. i honestly never seen one and ive been in quite a few shops.
__________________
Old 09-13-2009, 07:44 AM   #6
baxtej44
baxtej44's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.9L
Class: 4x4
Default
okay, well just wondering on the exact specs....
distance from wall and the height off floor and the space in between the foci of the beams.
__________________
Photobucket:
Old 09-13-2009, 01:15 PM   #7
cocoasranger
cocoasranger's Avatar
Year: 1989
Make: Ford
Model: Ranger
cocoasranger is on a distinguished road
Default
They mainly use them in states where there is an annual safety inspection requirement such as Pa. The Chilton or similar repair manuals show how to adjust them yourself by shining the beams against a wall.
__________________
89 Ranger 4wd std. cab, long bed w. 2.9L and Mazda M5OD R-1 trans. Manual 13-50 transfer case, 10 clutch and starter upgrade. Manual locking hubs, explorer leaf spring upgrade, 93-94 clutch master upgrade for better feel.
cocoasranger is offline   Reply With Quote
Old 09-13-2009, 03:39 PM   #8
baxtej44
baxtej44's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.9L
Class: 4x4
Default
Quote:
thanks, i'll check out my haynes
__________________
Photobucket:
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
