| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3 flowmaster 40, k&n air filter
Class: 2WD
Rep Power: 0 ![]() iTrader: (0)
i was wondering what would i have have to do if i upgrade to a bigger cam and still keep fuel injection. 1991 ranger 2.3
Tweet
#2 |
Year: 1994
Make: ford
Model: ranger 2.3 2wd with a few power mods
Class: 2wd
Used For: dd
Rep Power: 9 ![]() iTrader: (0)
look on the from pages some time
http://deltacam.com/index.php they got one computer friendly for $90 and this was on a thred on the next page look around noone likes to repeat thereself
__________________
i lika da fast i lika da drive fast i lika da drink fast and i lika da **** fast |
Tweet
#3 |
Year: 1994
Make: ford
Class: 2wd
Used For: dd
oh sorry man newcommer welcom to the from thanks for joining
__________________
Tweet
#5 |
Year: 1989
Make: Ford
Model: bronco II
Engine: 2.9
Class: 4x4
Used For: intertainment
you can only go like one size bigger on a 2.3 cam due to the clearance in the head. anything bigger and youll need machine work done.
__________________
1989 Bronco II, 4x4, 2in. body lift, 2.9 with crane cam, MSD igintion chip, air/fuel ratio chip, centerforce clutch, ARP bolts in motor. |
Tweet
#6 |
Year: 1994
Make: ford
Class: 2wd
Used For: dd
what kind of head work
__________________
Tweet
#7 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.0
Class: 2wd street
Used For: work
Rep Power: 8 ![]() iTrader: (0)
go to the link that was suggested up above and contact them @ delta they know what they are doing and you won't have to guess.
if you call them ask for scott or john. they have been racing these engines for yrs. |
Tweet
#8 |
Year: 1994
Make: ford
Class: 2wd
Used For: dd
thanks man
so how much power can you guys get out of a n/a 2.3
__________________
Tweet
#9 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 2.3l 4cyl
Class: 2WD Street
Used For: Daily Driven/Toy Hauler
not much without stroking it and porting the hell outta it and alot of other machining, turbo is the best route to get the most outta 2.3s far as i know.
__________________
88 2.3 XLT 5 Speed,Lowered 2 Inches, Custom Side Outlet Exhaust...Few Other Things....
Tweet
#10 |
Year: 2005
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2wd
Rep Power: 10 ![]() iTrader: (0)
Cam is a waste of time and money, N/A.
If you go with a delta cam, you need to run lash caps or your rocker arm geometry will be all messed up, and you could potentially have problems. The 2.3 has one of the most complicated rocker arm geometry setups of any engine. You have measure the base circle of the cam, Stock vs. Mod. and make the difference up with lash caps. Even though I like delta cams, and have used their cams quite a bit, I would not put a reduced base circle cam in a 2.3.
__________________
-05 ranger 2wd 3.0 M5OD -90 BII/4.0 SOHC-EEC-IV/M5OD/1354m/D35/Welded 8.8/Mutt lift/34"LTB's/Navajo Front clip...http://www.therangerstation.com/foru...ad.php?t=35258 |
Tweet
#11 |
Year: 1988
Make: Ford
Model: Ranger
Engine: 2.0
Class: 2wd street
Used For: work
you can get a cam from delta cams with a factory sized base circle.
you need to talk to them. before you do anything and like I said they know these engines very well. call THEM |
Tweet
#12 |
Year: 1994
Make: ford
Class: 2wd
Used For: dd
what kinda of crank for a stroker up grade
one compleatly new or out of another engine
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
