Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 08-25-2009, 06:53 PM   #1
belovedb2
Year: 1986
Make: Ford
Model: Bronco 2
belovedb2 is on a distinguished road
Default 4.0L Engine Swap - Engine removal Question
This may seem like a stupid question for all you experts. Where do I attach the engine hoist chain to the 4.0L engine that I am removing from my 93 explorer doner vehicle? I do not want to break anything by using something to weak. Where is the correct spot? Do I need to buy a special bracket or plate? Thanks Update: I just noticed on the 2.9L engine some heavy wire loops that are bolted on each side of the engine. I suspect these were used for installing the engine. Can I use the same loops for the 4.0L engine?
After looking at each engine I think I can use the same loops. I need to verify after I remove the loops. The only issue is the center of gravity. I am guessing the loops are set with the trans attached to the engine. I am removing the engine without the trans.
belovedb2 is offline   Reply With Quote
Old 08-26-2009, 10:56 PM   #2
trail B2
trail B2's Avatar
Year: 1986
Make: ford
Model: bronco 2
Engine: 4.0
Class: 4x4
Used For: 4x4 and DD
trail B2 will become famous soon enough
Default Pull engine
I just used accessory air cond bolts I think and put A bolt in the intake on the back but I had one of those screw adjusters to tip the motor how I wanted.
trail B2 is offline   Reply With Quote
Old 08-27-2009, 01:31 AM   #3
Fx4wannabe01
February 2010 OTOTM Winner
Fx4wannabe01's Avatar
Year: 2001
Make: Ford
Model: Ranger
Class: Snow Wheeler/DD
Used For: Pickin' up chicks.
Fx4wannabe01 is on a distinguished road
Default
in between a few runners on the exhaust maifolds, are dedicated empty bolt holes for your lifting chains. Use a spreader bar. I just swapped engines in my '01 4.0. Your holes may be different on the OHV though.
Fx4wannabe01 is offline   Reply With Quote
Old 08-27-2009, 09:34 AM   #4
BlackBII
Cheaf of Grammor Poleace
BlackBII's Avatar
Year: 1989
Make: Ford
Model: Ranger
Engine: 2.3
Class: 4x4
Used For: Getting irritated
BlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to beholdBlackBII is a splendid one to behold
Default
There should be empty bolt holes on the side of each head. I usually hook one end on the back and one on the front - opposite sides. Lifts out more evenly that way.
__________________
I hate all RBV's, especially the ones I own.
BlackBII is offline   Reply With Quote
Old 08-27-2009, 09:41 AM   #5
rickcdewitt
rickcdewitt's Avatar
Year: 1991
Make: ford
Model: ranger-needs more lift
Engine: 4-0 swap
Class: 4x4
Used For: work and play
rickcdewitt is on a distinguished road
Default
i put the lift tabs from a 2.9 on the exhaust bolt holes mentioned
__________________
4.10's, 33's, duff stage 3 w/4" coils, cb,cowl snorkle, homemade high clearance d-ring bumpers,bobbed bed,8.8
My bobtail beater
Quote:
Originally Posted by fastpakr
Try to stick to posting about trucks, unless you can figure out a way to control yourself.
rickcdewitt is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
