OBD2 PCM Tests
Falkyn1
15+ Year Member
After just spending 5 days trying like crazy trying to get my PCM to test all sensors for emissions, I finally got it. What help me the most was a couple of websites I found and figured to share with you all.
http://www.motorcraftservice.com/vdirs/retail/default.asp?pageid=pubs&gutsid=pubs_workshop
Under OBDII Theory & Operation on the left side has .pdf files for free download for every year model from 1996 to 2007 and also for the diesel engines. these tell you about the system/test and what conditions need to be meet so the tests will run.
http://www.obdii.com/drivecycleford.html
This website has a step by step procedure for doing all the tests but i think you need to have the company's scanner but it did help.
I hope this helps you all like it helped me.
