Go Back   The Ranger Station Forums > TRS Photo & Video Galleries > Your Garage > Off-Road Rangers Under Construction
Notices
Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress.
Post New Thread Reply
Thread Tools Display Modes
Old 11-18-2007, 09:06 AM   #1
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Used For: a chicken house
Will is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to behold
Default Extending a wheelbase...
Thinking about chopping my old Winnebago up to make a toter-home out of it. To pull this off I really need to add 31" to the wheelbase. There's a section before the back axle that is straight and 34" long with no obstructions or crossmembers. I could cut that in half and add 2 65" sections there, doubling it 17" on each end, but it's only 2" from the frame to the bottom of the motorhome and I don't think I can weld in that gap. Would putting a shitload of bolts instead be better? I've seen straight trucks with the frame lengthend by bolting.
The other option is to cut it off and not re-use the back half of the existing frame. I can double it as far forward as it practical and bolt the leaf hangers to my added section.
One problem is there isn't a standard channel available that will just snuggly fit in there.
This is what the frame looks like, but it's not mine. I'm not wanting to tear the floor out. My boosters are way up front and not in the way as they are on this one.
This is what the machine looks like now:
This is what I want it to look like. I can't leave enough space inside and use a gooseneck hitch without the wheelbase extension.
__________________
'83 Ranger cab, '89 B2 frame, 4.0, C5, D35/8.8, 4.10s, Lockrights.
'87 Chevy crew 6.2 Banks turbodiesel TH400 GearVendors 4.10 14-bolt Detroit
'96 VW Passat Tdi
'00 Ford E350 15-pax Powerstroke
'09 Suzuki TU250X
'04 Moto Guzzi Breva
http://willwills.com/
Will is offline   Reply With Quote
Old 11-18-2007, 09:21 AM   #2
red85
red85's Avatar
Year: 1985
Make: Ford
Model: Ranger
Engine: 306 ci
Class: 2WD Street
Used For: making noise and burning gas
red85 is on a distinguished road
Send a message via MSN to red85
Default
I would recommend welding the frame, Will. Remember the old Citroen 2cv's? They were bolted together and they would basically disassemble themselves over time. What about bolting it together and then welding the bolts? That way the frame would be allowed to flex (like a transport truck) and you wouldn't have to worry about a weld breaking or a bolt coming out.
Phil
__________________
Professional Auto Service Tech
1996 Ranger XLT - 3.0 A4LD
1985 Ranger S - 306 ci/C4 (12.96 1/4)gone but not forgotten
1994 Ranger XL - 2.3T/M50D R1 (sadly retired now - Salt cancer got her)
2008 Ranger Sport - 3.0/M5OD R1
Don't ask a question if you don't want to hear the answer!
Putting brains before dollars since 1970
red85 is offline   Reply With Quote
Old 11-24-2007, 10:10 AM   #3
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Default Ford tech?
Quote:
The frame splice technique, and the methods used to splice and re-connect the related vehicle
systems, must be in accordance with the guidelines established in MVE-11 and QVM Bulletin Q-18,
Guidelines for Modifying Ford Light Truck Wheelbases.
Does anyone have a copy of this available?
__________________
'96 VW Passat Tdi
'09 Suzuki TU250X
Old 11-24-2007, 10:29 AM   #4
almostclueless
almostclueless's Avatar
Year: 98
Make: ford
Model: ranger
almostclueless is on a distinguished road
Default
Sounds like the perfect technique to be messed up by subpar techs LOL
__________________
1. MORE COWBELL!
2. Chuck Norris can win Connect Four in three moves.
3. What the H___ is an aluminum falcon!?!
4. sham....WOWWWW
almostclueless is offline   Reply With Quote
Old 11-24-2007, 12:00 PM   #5
Dave R
RBV Technical Advisor
Year: 1953
Make: Kaiser
Model: Chief
Dave R is on a distinguished road
Default
Have you tried this....
MVE11
or this.....
chassis stretching
Chassis stretching/shrinking isn't that difficult. Just make sure your filler and reinforcing plates are as thick or thicker than the original frame. Measure and cut carefully, then measure 5-6 times to ensure everything is square and straight before you tack it together. Then measure one or two more times before fully welding and attaching the reinforcing plates, to both the inside and the outside joints. Also, yor reinforcing plates should not be square, if that's not clear, note picture 9 of the station 2 section in the second link.
Dave R is offline   Reply With Quote
Old 11-24-2007, 02:40 PM   #6
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Default
Good article Dave, thanks. Hard to see exactly what's going on it there. What I think I see in that picture is the extension piece is the same dimentsion as the frame, and is butt welded in there. Than the diamond plates are added to the inside--2 per side. After that, the reinforcement angle is only on the bottom flange and goes up the outside. Is that what you see in there?
Trying to squint into those pictures is killing my eyes.
The crap I've seen welded together on truck frames makes me think just about anything would hold if the welds were well done.
__________________
'96 VW Passat Tdi
'09 Suzuki TU250X
Old 11-24-2007, 02:45 PM   #7
almostclueless
Year: 98
Make: ford
Model: ranger
Default
Thats surprising to me. I wonder how many truck frames are heat treated and how much it is affected by welding.
__________________
1. MORE COWBELL!
4. sham....WOWWWW
Old 11-24-2007, 06:00 PM   #8
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Default
There's nothing special about most truck frames. It's just steel. It's not hard to make it strong enough, the factor that concerns me is the amount of twisting and bending a frame sees in normal use--you want to avoid a hard spot--a sudden change in the stiffness of the frame. I wanted to make sure I followed an established procedure to account for those things I am not qualified to think about.
__________________
'96 VW Passat Tdi
'09 Suzuki TU250X
Old 11-25-2007, 08:36 AM   #9
Dave R
Year: 1953
Make: Kaiser
Model: Chief
Default
Quote:
Man, you are getting old. But, then again after doing it 6-7 times myself I know what their doing.
Yep, that's about it. The most important thing is making 100% sure that you extend each side the same amount and you keep the frame straight and level. The diamond shaped interior plates need to go over the joint(s) i.e. one plate per side for shortening a frame and two per side for lengthening. Personally, I've always put the exterior reinforcing plates on both the top and the bottom but, technically, it's only required on the bottom. If you want to get into the overkill end of things, instead of using angle as the exterior reinforcement, use a 1/4" strip as wide as the frame, fully welded, on the top and underside extending about 6-12" beyond the joints in both directions. Then add a side plate, also 1/4" thick, as tall as the frame on the side, also extending 6-12" fore and aft of the joints. It's a lot of welding and quite a bit of weight but it isn't going ANYWHERE once your done.
Ain't that the truth. A friend of mine drove/ran a medium sized crane truck for a somewhat "fly-by-night" operation, that thing was in the shop nearly every year having it's frame reinforced.
Old 11-25-2007, 11:39 AM   #10
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Default
Thanks Dave. That's the proceedure I'm going to follow, at least as closely as I can. My frame isn't a standard dimension channel so I may have to deviate a bit.
This beauty has 4 bolts per end holding the frame extension--and nothing else. Of course the giant piece of bridge timber and the steel deck also help.
And in lieu of the diamond plates, these guys cut the shape into it. I think that's all they do--cut the extension into the same shape and weld it up. It also gets a truck body bolted to it so that reinforced it a lot I guess.
__________________
'96 VW Passat Tdi
'09 Suzuki TU250X
Old 11-25-2007, 12:18 PM   #11
Jspafford
Logan Andrew Feb 17, 2012
Jspafford's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9L
Class: 4x4
Used For: Getting Passed
Jspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of lightJspafford is a glorious beacon of light
Default
Will, are you working on the Winnie?
Jspafford is offline   Reply With Quote
Old 11-25-2007, 03:37 PM   #12
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Default
I pulled the old thing up by the garage last week. I'm making my plans and sharpening my angle grinder. I'm not absolutely commited but I'm pretty convinced life on the planet will suffer if I don't do this.
__________________
'96 VW Passat Tdi
'09 Suzuki TU250X
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
