Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 11-16-2007, 07:13 PM   #1
Kirk
Year: 2002
Make: Ford
Model: Ranger
Kirk is on a distinguished road
Question squeaking noise
I have a '02 Ranger with a V-6. About a week ago it started making a squeeling sound at idle and when driving, it sounds like a belt squeaking. I took it to the shop today and they found nothing. We changed the belt and tried a new alternator. No cure, still squeaks. They said it sounded internal (maybe a rocker) but I find that hard to believe. It runs smooth, no power loss. I swear it sounds like a belt or pulley, it's driving me crazy. They said to try some Lucas oil treatment and maybe that would help. So, belt - $49.99, stupid looks - STILL FREE!! Anybody got any ideas?
Thanks,
Kirk is offline   Reply With Quote
Old 11-17-2007, 09:24 AM   #2
4x4RangerGuy
4x4RangerGuy's Avatar
Year: 2003
Make: Subaru
Model: Impreza WRX
Engine: 2.0
Class: AWD
Used For: DD, showing up ricers, fun
4x4RangerGuy is on a distinguished road
Default
It's almost always the idler pulley, and to a lesser extent, the serpentine belt tensioner. The idler pulleys on 3.0s have a bad bearing design and go quite often.
Replace the idler pulley (cheap), but ALSO replace your tensioner. What happens is the idler pulley will start to move around due to the bad bearing and wear out the tensioner as it does this. Therefore, to really solve the issue, both need to be replaced. It isn't expensive and you can do it in your driveway.
__________________
1998 Ranger XLT 4x4 SOLD
2003 Subaru Impreza WRX
Still the 3.0's biggest fan.
4x4RangerGuy is offline   Reply With Quote
Old 11-17-2007, 10:46 AM   #3
dangeranger
dangeranger is on a distinguished road
Default
have you checked your camshaft synchronizer???? they squeal when they are on the way out and it will sound internal, like its coming from behind the radio....
__________________
1999 Ranger 3.0 4x4, 3in BL, custom bumpers, lots of lights, sittin on 33's
TRS Member since July 2004....Amen
dangeranger is offline   Reply With Quote
Old 11-18-2007, 08:32 PM   #4
Kirk
Year: 2002
Make: Ford
Model: Ranger
Default
Quote:
Turns out it is the camshaft synchronizer. Pulled the belt off completely and it still squeeled so we knew it wasn't a pulley. I couldn't get a camshaft synchronizer today put pulled the cover off and shot some PB down in there and it took the squeel away. It'll come back as the lube dries up but at least it took it away until I can get the part.
Old 11-19-2007, 03:00 AM   #5
funkingonutz
funkingonutz's Avatar
Year: 1995
Make: Ford
Model: Ranger XLT SUPER Cab
Engine: 3.slow
Class: 4x4
Used For: collecting bird poo
funkingonutz is on a distinguished road
Default
wait....you took off the belt and started up the truck?? correct....if it ran thats wierd because my friends cadillac Northstar belt snapped and the motor died and would'nt start back up until we put a new belt on. maybe it was just a "caddy thing"
__________________
I drive a FORD
funkingonutz is offline   Reply With Quote
Old 11-19-2007, 03:04 AM   #6
funkingonutz
Year: 1995
Make: Ford
Engine: 3.slow
Class: 4x4
Default
wait does the squeal sound like a bad wheel bearing, because if so then that might be my problem too, im hearing a constant squeal(like an electric wheelchair sound), and i replaced the wheel bearings today and im still hearing it, its not loud but its driving me crazy.
__________________
I drive a FORD
Old 11-19-2007, 08:59 AM   #7
Psychopete
Psychopete's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: NONE
Class: 2WD
Used For: Working on
Psychopete is just really nicePsychopete is just really nicePsychopete is just really nicePsychopete is just really nice
Default
Just follow the same steps Kirk took, if the noise is from from the back of the engine, the CPS is more than like the problem, especially if you have over 100K and it's never been replaced before. It's critical that this sensor does not completely fail.
Pete
Psychopete is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
