Running wires for light bar
1950BIKER
10+ Year Member
Is there an easy way to run the wires for a roof mounted light bar into the cab of an 02 Ranger Supercab without drilling holes in the body, wire harness in approx 3/4 in dia. Lightbar is for the volunteer fire dept.
well you could drop it in the door jam.
or you could just dropit down behind the cab & run it up the frame into the fire wall then run a switch off the battery or take out the fuse panel & dip into the radio harness & get feed from there! (but if its a 20amp mite wanna jump to a 30) or any open fused line
post a pic when your done with how it looks ive always wanted to see what it looks like
or do wat me and my buddy did for our cb cable. if u got teh jump seats int eh back, then theres a rubber grommet int eh bottom that u can cut a slit in and put the wires thru it
