- Aug 6, 2009
I have a 94 Ranger 5-speed 2.3L with multi-port fuel injection and 260 K miles on the original engine with no major engine work. I recently removed the air muffler and re-built the CAI using 3" ABS pipe. I got a noticeable increase in responsiveness and even documented a 5% - 9% increase in MPG. However I still use the stock air box and the standard air filter designed for my truck.
I understand that the computer for my truck uses the TPS by default to determine how much fuel to use whenever there is no signal from the MAF sensor. Since I have already reduced the air restriction on the intake if I unplug the MAF in theory it will further lean out the A/F ratio and give me better MPG. In a test I did this morning it ran almost like it did with the MAF plugged in, with a cold and then warm engine.
My question is how can I tell if it's too lean? What kind of signs will I need to look for? And what could be the long term effects if I leave it unplugged indefinitely?
Ultimately I plan on adding a Hydrogen Injection system, no not one of those on-board electrolysis system, a true H2 injection system using a H2 storage tank. My goal is to top 40 MPG in my old truck.
Any thoughts from anyone?
