| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1987
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: Disturbing the Peace
Rep Power: 9 ![]() iTrader: (1)
So ive just replaced the head gaskets along with every other gasket in my 2.9 87 ranger. Fixed my white smoke problem but now i have an oil leak(looks like its coming from the left side). Along with the oil im getting smoke strait from under the hood which is more than likely the oil burning. I thought it might be the valve cover leaking oil out but i took that off today and cleaned it very well and sealed the bolt holes with some RTV. Anyone have a thought before I take it to a mechanic? |
Tweet
#3 |
Year: 2000
Make: GMC
Model: Slownoma
Engine: 4.3
Class: 4X4
Used For: daily...pain in the ass.
Rep Power: 0 ![]() iTrader: (0)
could possibly be the head. you might not of tightened one of the head bolts all the way. the same thing happened to my freinds neon. he replaced all the gaskets from the head up and had the leak
__________________
Tell me I can't...and I promise I will 1989 Metro, 1984 Ranger 4X4, 1991 Colt, 1986 Ranger STX, 1986 F150, 1994 Pathfinder, 1994 Ranger, 2000 Sonoma 4X4 LOUD LOW AND SLOW |
Tweet
#4 |
Year: 1989
Make: Ford
Model: Ranger
Rep Power: 13 ![]() iTrader: (0)
Most likely the valve cover gaskets are still leaking. Sometimes it takes a couple tries to stop them from leaking. The oil drops onto the hot exhaust manifold and clouds of smoke roll out from under the hood. I could even smell burned oil in the cab with the windows closed on mine.
Search valve cover gasket on this site and you will find numerous threads on what to watch out for when installing them. I used rubber/cork gaskets, but would use the blue neoprene if I was to do it again.
__________________
89 Ranger 4wd std. cab, long bed w. 2.9L and Mazda M5OD R-1 trans. Manual 13-50 transfer case, 10 clutch and starter upgrade. Manual locking hubs, explorer leaf spring upgrade, 93-94 clutch master upgrade for better feel. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
