Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4-bangers > 4-Cylinder (2001 & Newer)
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 07-30-2009, 12:17 PM   #1
bdagle
bdagle is on a distinguished road
Default Need Help on 2.3 replacement
I have 2001 2.3 Ranger with manual trans. The motor is very very tired and I want to replace it. The information I can find on what will fit is very conflicting. Does the replacement engine have to be from a standard transmission truck? Will any 2.3 Duratec engine fit or does it have to be the 23NS made in Dearborn for this truck? Does the year that the engine was made make any differance? Thanks for any and all help! Brendan
bdagle is offline   Reply With Quote
Old 08-06-2009, 08:00 PM   #2
bdagle
Default Somebody as why a new engine?
I know these Ford 2.3's are supposed to be almost industructable and mine only has 77K on it. What happened is that on the way home from a trip, I noticed that I was blowing lots of black smoke out the tail pipe. I didn't have any choice so I just drove it home. When I got home I worked for about two weeks trouble shooting the problem, everything looked OK and the computer showed no codes. Finally in desperation I removed the intake manifold and found that the swirl dampers were jamed closed and that the ball and socket from the actuater had seperated (You can't see this with the manifold on the engine). I was able to free up the dampers and repair the ball and socket. No more black smoke, but lots of blue smoke. The oil was way over full and contaminated with gasoline. I changed the oil, but it is burning at the rate of 1qt per 100 miles. I must have washed down the cylinder walls and ruined the rings.
Old 08-13-2009, 07:26 AM   #3
dorman68
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
dorman68 is on a distinguished road
Default
Here is info I got from a salvage interchange. These are what will fit your truck.
MAZDA B2300 2001-02 (2.3L, VIN D)
RANGER 2001-02 (2.3L, VIN D)
Electrical & induction parts may vary, compare and switch as necessary.
__________________
1993 Ranger 2.3L,5-spd-2wd - 149,000 mi.(slow as dog-dirt)
1994 Ranger 2.3L,Auto-2wd - 155,000 mi.(Sold)
2005 Corolla LE - AT Trans
dorman68 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
