| Home | Resources | Tech Library | Magazine | Video Gallery | Truck Gallery | Shirts & Decals | Parts |
| Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral |
Thread Tools | Display Modes |
#1 |
Year: 1986
Make: Ford
Model: Bronco II Eddie Bauer
Engine: 2.9 v6 EFI
Class: 4x4 Extreme
Used For: 4Wheeling, Hunting, and Wilderness Exploration
Rep Power: 0 ![]() iTrader: (0)
I have a 1986 ford bronco II, 2.9. If I have a fully charged battery or if I jump start it, it will start and run forever but after Running for a while, if I shut it off and try to start it again the battery will be totally drained. I have replaced the altenator which didn't fix it, and I have tried different batteries and same thing.
Some one please shine some light on this. I can't figure it out. Thanks. |
#2 |
![]() Join Date: Nov 2007
Year: 1989 1999
Make: ford
Model: Bronco II and f-150
Engine: 289/5.4l
Class: 4x4
Used For: toy/dd
Rep Power: 7 ![]() iTrader: (1)
take a voltmeter to the battery and see if its around 14v,while running thats means the alternators working properly, if it says about 12v or less it could be the wiring or in the alternator somewhere
__________________
1999 f-150 5.4l/4r70w/3.55 4x4 ext cab pionner deck, 30 gig hd for music, cobra cb,cold air intake/tb space, cranked T-bars, LT265/75/r16 E tires 3" body lift 1989 Bronco II 4wd 67 289 /AOD/np208 unfinished 2003 Honda shadow ACE 750cc from the old board, missing the wrenches |
#3 |
Year: 1986
Make: Ford
Model: Ranger
Engine: 2.9 v6
Class: 4x4
Used For: Picking up chicks
Rep Power: 4 ![]() iTrader: (0)
Mine did the same thing and it turned out to be the ground wire. it looked fine but the inside was all corroted. Good Luck!
#4 |
Year: 1984
Make: Ford
Model: Bronco II
Engine: 2.8
Class: 4x4
Rep Power: 3 ![]() iTrader: (0)
x2 on checking the wires, even if they look fine they can be corroded on the inside. Check their connections first though, then replace the wires.
__________________
Its only metal, it puts up a good fight, but in the end, it loses. -Cisco Kid Customs- |
#5 |
Year: 1986/2005
Make: Ford
Model: Ranger
Engine: 350 chev/3.0
Class: 2WD
Rep Power: 6 ![]() iTrader: (0)
make sure you don't have a draw on the battery with the key off check for dome light staying on, stuff like that. Also as said check running voltage to see if it is charging, you can use a jumper cable as a temporary ground if you don't have extra cables lying around.
#6 |
Junior Member
Year: 1999
1998
197
Make: Ford
Jee
Model: Ranger
Explorer
CJ5
Engine: 3.0, 4.0 304V8
Class: 4x4
My 88 did the same thing, turned out to be that when the battery cables were replaced, they routed them too close to the exhaust manifold, the cables would heat up and not conduct electricity down to the starter. For the cost to replace the battery cables, I'd try that first, making sure to route the cables away from extreme heat sources.
#7 |
Year: 1986
Make: Ford
Engine: 2.9 v6 EFI
Class: 4x4 Extreme
Thanks every one I will take a look at all this and see if it works thanks
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| bye bye bronco | Boggin | General Discussions | 15 | 07-10-2009 05:45 PM |
| bronco 2 trany problem | rangerman69 | General Discussions | 0 | 05-31-2009 05:37 AM |
| New member from NC with a 90' Bronco II | Mtrhd0024 | Introduce Yourself | 5 | 03-06-2009 08:32 AM |
| Axle Guide For All Trucks - minor update | p4x28x2 | Ranger Axles | 0 | 06-29-2008 08:50 PM |
