| Home | Resources | Tech Library | Magazine | Video Gallery | Truck Gallery | Shirts & Decals | Parts |
#1 |
Hi,
I have a ford ranger '90 2.9L EFI. I'm suspecting a fuel pressure regulator (FPR) problem so I made a pressure test. The result is bugging me! With the key to ON, on the first fuel pump activation I have a reading of 0 (Zero) PSI. To get the needed 40 PSI I had to activate the pump 5 times. And that's not all! If I don't touch anything, the pressure start going down until it reach zero. Then I started the engine and got a constant reading of about 78 PSI. With these results, should I consider that my FPR is faulty or a vacuum problem? |
#2 |
Junior Member
Year: 1990
Make: Ford
Model: Bronco II
Built: 12/89
3.73 Axle
Mitsubishi Trans
Engine: 2.9
Class: 4x4 Stock
Used For: 95-On/5-Off Road
Rep Power: 3 ![]() iTrader: (0)
It would be safe to say that the regulator is shot. You are getting full pump pressure. As for the pressure dropping after shutting engine off, the injectors are leaking. Pressure should hold for at least an hour before you start to see any pressure drop off. Time to get some rebuilt injectors. Don't drive it until after you get the regulator changed out...will cause engine damage. After the regulator swap, change oil/filter. The oil will be diluted from the excess gas.
__________________
1990 Bronco II (12/89) |
#3 |
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9L
Class: 4x4
Used For: Everyday driver
sevynos mine acted very similar when my FPR was shot. It would jump up to almost 80 then slowly drop down. I ran fuel injector cleaner in it several times and replaced the FPR and now the pressure reads good and doesn't drop off anymore.
#4 |
RBV Technical Advisor
![]() Join Date: Aug 2007
Year: 1988
Make: FORD
Model: RANGERISH SORT OF THING
Engine: BIGGER
Class: 4X4
Used For: EVERTHING
Rep Power: 30 ![]() iTrader: (0)
sounds more like a pump issue to me. or rather a cobination of it...as in the pump check valve failed..but an open injector would do that...the 70 psi though dont jive that..that or the return line is plugged and caused the c/v failure in the pump or something.
without pulling the return line to check for volume i cant really say. i would do that before buying parts. be very careful when working with the fuel lines, dont want to burn yourself down.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESELBLAHHHHH motating a 4l80 thats authoritivly turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now
#5 |
Thanks to all for your replies.
According to your oppinions, some on another forum and people i've talked to, i will replace the FPR since I found an affordable one at CarQuest. Anyway, it won't hurt to get a new one! bobbywalter: I'm no expert but if it is a pump issue, I think I shouldn't get a 78PSI pressure instantly after startup. Am I wrong? Again, thanks to all! |
#6 |
Ford Trained Technician
![]() ![]() Join Date: Aug 2007
Year: 1991
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: Daily Driver/ Weekend Warrior
Rep Power: 10 ![]() ![]() iTrader: (0)
Yes but it sounds like the pump is leaking down, and not holding the fuel pressure which is why you would have to cycle the key 5 times like you say you do. All the fuel has drained back out the lines and into the tank.
__________________
http://www.coastmountaincrawlers.com 1991 Ranger - 7" lift, cut fenders, 36" TSL SX's, Detroit locked 31 spline 8.8, Aussie Locked d35, 5-760X joints, 4.56 gears. 1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's. 2005 Explorer Sport Trac - Tbar crank, 265/75r16 Procomp AT's, clear corners. 1972 Mustang Coupe - 302, c4, 9", 4.11's locked. |
#8 |
Year: 2002
Make: Ford
Model: Ranger FX4
Engine: 4.0 SOHC
Class: 4X4
Used For: Daily driver, towing & off-road
Rep Power: 7 ![]() iTrader: (0)
I had a similar problem with an 89 2.9L Ranger and recently with my 02. Replacing the fuel pump solved the problem. The check valve was not working properly and I would have to cycle the ignition key 4 to 5 times to get the engine to start. The pressure would not build to full pressure when turning on the ignition switch because not enough volume would pump before the pump automatically shut off.
The check valve is not the only thing that causes this problem but if the new FPR does not solve the problem you should take a hard look at the fuel pump. I find the quickest way to check that is; disconnect the fuel filter and connect a pressure gauge to the line coming from the tank. Cycle the ignition switch and if the pressure drops off when you shut of the ignition switch, the check valve is not functioning properly.
__________________
2002 FX4 - 4.0 SOHC, 5 spd manual transmission & transfer case, 32" ProComp MTs, K&N air filter, Modified air box inlet, Gibson SS cat. back exhaust, Bama flash, Hidden Hitch round receiver, Rear helper air springs, electric trailer brake controller, Line-X bed liner, WAAG bar with KC lights and Wildernest shell. |
#9 |
Year: 1992
Make: Ford
Model: Ranger SuperCab
Engine: 4.0
Rep Power: 5 ![]() iTrader: (0)
Where do you connect the fuel pressure gauge to?
__________________
I'm not asking you to fix it, just please let me get it back to the way it was before I touched it. The Technician Prayer |
#10 | |
Premium Member
Year: 1988
Make: Ford
Model: Ranger
Engine: 5.0L
Class: 2WD
Used For: Beating on
Rep Power: 11 ![]() iTrader: (4)
The schrader valve on the fuel rail.
Pete
__________________
1988 Ford Ranger Red 5.0L AOD 2WD 1993 Ford Tempo Tomato Red 2.3L HSC Auto 1993 Ford Tempo Tree Green 2.3L HSC Auto (Red's Replacement) 2002 Dodge Caravan Blue 3.3L V6 Auto Quote:
#11 |
Year: 2002
Make: Ford
Model: Ranger FX4
Engine: 4.0 SOHC
Class: 4X4
I connect it to the end of the fuel line. It might take some ingenuity to come up with a good connection with some fuel pressure gauges. I have one that has a tapered fitting that fits inside the line and requires holding them together. That requires a helper to cycle the ignition switch.
__________________
#12 |
Finally I installed my new FPR yesterday.
Truck runs well and startup are much more easier! Now my pressure reads 37-38 on key ON position. There's seem to have a small leak, in about 5 minutes engine off, I lost 10 PSI. When the engine is running, the pressure climbs to 40 and stay there. It's the opposite of specifications. Anybody have an idea? And there's now another little issue about the gas! When I hit accelerator, the pressure and engine RPM drops a little to go back up after 1-2 seconds. I've seen this before but I don't remember what it was. Anybody knows? |
#13 |
![]() Join Date: Jan 2009
Year: 1987
Make: Ford
Model: Ranger STX
Engine: 2.9
Class: 4x4
Used For: Killing Deer
Rep Power: 4 ![]() iTrader: (0)
Check the little black canister under the drivers door. Should be 4 lines connected to it. Make sure that isnt leaking. Its a left over from the days Ford used canister fuel filters, instead of in line, there is no longer a filter in it.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Correct fuel pressure in '03 with 3.0 flex | williamigriffith | 3.0 Liter Forum | 5 | 07-15-2009 06:50 PM |
| Tips for diagnosing fuel system | HndMeDnBroncoII | 2.9 Liter Forum | 0 | 11-24-2008 01:44 PM |
| HOW TO: Setup Nitrous Oxide on a daily driver. | rocket5979 | Forced Induction | 3 | 03-16-2008 01:31 PM |
| 2.9 Dosent hold fuel pressure | 177CIOfPureLove | 2.9 Liter Forum | 6 | 11-10-2007 02:12 PM |
| from old 4.0 swap | MrE_Powers | 'Other' Engine Conversions | 0 | 08-08-2007 08:40 AM |
