solid axle swap
Blueranger99
15+ Year Member
lebanon, pa
does anyone in here have any experience with doin a solid axle swap on a 98 and newer ranger 4x4. how hard is the swap, and what kinda cost do you run into?
thanks ranger_mclaren. well judgin from what i read it seems like too much work. i think ill just stick to my ifs. maybe try to get a little more out of my torsion bar crankin, and bigger blocks in the rear.
It's not bad if you have a good plan, correct tools, and all the parts already.
If you can weld it's much easier.
I made a cross member for the front out of 3x6 rectange tube with .25" wall. I knotched it so it'd sit in the frame rails and then welded that in, and hangers to that. Some hangers in the rear, shackle one side or the other, u bolt that biotch in, run shocks and brake lines, mount a gear box some where, fab a column, run steering linkage, build a drive shaft, and you're good to go. With leafs that is. Which is what i did.
Check out project mooseknuckle in the build threads. Not much good info, but there's some. And some pretty pictures.
thanks man ill have to check it out. my dad can weld, and so can my landlord.
i still think im gonna stick with my ifs. i run a set of 31 inch treadwright retreads and with my torsion bars cranked it seems like i got some pretty good ground clearance in the front which i like because that is where all the weight is. i went wheelin yesterday and went through some pretty hairy stuff no problem. im happy with it. but im lookin at gettin a second truck. my landliord has an 80s f150 4x4 with a 3 inch body lift on it. it quit runnin bout 6 months ago. i dont think the motor went, i just dont think he had any desire to work on it. it has an inline 6 with a 5 spd. im gonna try to get it for a few hundred. if i cant get the motor runnin, ill swap a 5.0 in it. then will come a 6 inch suspension lift and 35s or 37s.
