| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| 4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks |
Thread Tools | Display Modes |
#1 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 4wd
Used For: Haulin', muddin', general shit-kickin'
Rep Power: 0 ![]() iTrader: (0)
just bought a slide in/pop-up camper for my '97 4.0. the plan is a x-country trip next month. i brought it home 70 miles, and it actually did ok, but it looks like the rear end is straining. truck has 185k miles on it; probably original shocks. trying to figure out the best way to minimize strain on the suspension. looks like the best thing i've found is a bolt on air suspension like so: http://www.suspensionconnection.com/...con/2172F.html.
it needs to be cheap and easy to install--this looks like it would fit the bill, though i'm certainly open to other suggestions. PO said the camper was ~600#, but i think it's more than that, maybe 1000. i'm going to get it weighed soon. |
Tweet
#2 |
Year: 2006
Make: Ford
Model: F-150 XLT
Engine: 4.6
Class: 4x4
Used For: Work and Play
Rep Power: 11 ![]() iTrader: (0)
If your on the original shocks I would replace those just cause. Then from there, airbags are the only way to go.
__________________
Buy a hybrid my truck needs your gas |
Tweet
#3 |
Super Moderator
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Used For: a chicken house
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (1)
The rear axle rating is 2,750#. Keep that in mind when you weigh it. Pretty easy to overload it. Might be fine around town, but cross country, not as good. I don't know what you have, but THIS ONE weighs 1,170#. A 4x4 Ranger is typically 2,000# in the front and 1,400# in the rear. This leaves you about 1,350# of capacity so it won't take much to overload it. Sagging can be dealt with using airbags, but not overloading the axle itself. It's a semi-float so it has smaller bearings and they are both holding the weight and floating the axle shaft. I had an axle bearing fail on a 9" in the middle of Glacier National Park while pulling an overloaded U-Haul trailer on my Honeymoon.
__________________
'83 Ranger cab, '89 B2 frame, 4.0, C5, D35/8.8, 4.10s, Lockrights. '87 Chevy crew 6.2 Banks turbodiesel TH400 GearVendors 4.10 14-bolt Detroit '96 VW Passat Tdi '00 Ford E350 15-pax Powerstroke '09 Suzuki TU250X '04 Moto Guzzi Breva http://willwills.com/ |
Tweet
#4 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 4wd
hmmm. yeah, that looks similar to mine, though mine is much older and doesn't have a furnace or fridge--i'd imagine mine probably weighs a bit less. either way, it SHOULD be within the capacity of the truck. airbags looked like they'd take the strain off the springs and related components at least. as far as the bearings, looks like it would be a PITA to replace en route--any benefit to just replacing them before hand? i kind of doubt it, but who knows...
Tweet
#5 |
Year: 1996
Make: Mazda
Model: B2300
Engine: 2.3L
Class: 2wd Off-Road
Used For: Disposing of Funds $$$
I know this is a little out there... but the explorer 8.8 gives you a little better load rating at 3200lbs. Gives you a couple extra 100lbs of leeway. :E
__________________
'96 Mazda B2300, 6" Lift, 31" Swampers, Locked w/ 4.10's. NNYOffroad.com SSOffroad.com |
Tweet
#6 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 4wd
Yeah, that explorer axle looks like the way to go, but it looks like more work than I'll be able to do before I leave. Got weighed today, and came out to be 2680# rear and 2320 up front with a full tank of gas and a 50# dog in the cab...certainly cutting it close. I can't believe that the camper is that heavy--it's pretty basic. Looks like I'll be a little over the gawr no matter how light I pack; guess I'm just going to have to take my chances. Hopefully that gawr is conservative...
Tweet
#7 |
Year: 2006
Make: Ford
Model: F-150 XLT
Engine: 4.6
Class: 4x4
Have you taken a look at your GVW? I bet you'll be overloaded
__________________
Tweet
#8 |
Year: 1987
Make: Ford
Model: 87 stx
Engine: 4.0l sohc
Class: 4x4
Rep Power: 14 ![]() iTrader: (2)
If you don't mind how much did you pay for the camper? I have kinda been looking for one but every time I look they seem to be way pricey.
__________________
Plz no grammer NAZIS I know my spelling and grammer sucks. thanks. 2001 ranger 3.0l 2wd posed out with prerunner fronts. 1987 ranger 2.9l 4wd stx (swaping in 4.0l sohc trans and 8.8) ![]() 1969 mercury cougar conv. 351w virgin as mary ![]() 1964 MG Midget 1275cc motor ![]() 1996 mustang Gt conv. 4.6l steeda susp. parts |
Tweet
#9 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 4wd
@odie: $1000
@rangersport: no idea. My sticker's gone so I don't know the gvwr. Looks like the gcwr is 6-7k # depending on the diff. Google hasn't helped me with an answer so far... |
Tweet
#10 |
Premium Member
Year: 2003
Make: Ford
Model: Ranger XLT Ext Cab
Engine: 3.0
Class: 2WD Street
Used For: Summer Beater
Rep Power: 55 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
I had this stuck away for my reference on the 2000 Ranger, pages 12-15 cover some of what you want.
Dave https://www.fleet.ford.com/truckbbas...0/BBRANGER.PDF |
Tweet
#12 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 4wd
Thanks, though I'll have to wait till sunday to view it--doesn't work right on my BB. And do those #'s hold for a 97 as well? Replaced the shocks today, and found the source of metal grinding noise from rear--not bearings, which seem to be in good shape, but adjusting spring in drums sheared off and was rubbing. Lastly, I think to cut some weight I'm going to remove the spare and tailgate--should save me 100# anyway. I'll bring a patch kit/compressor and AAA. Probably shouldn't put that much weight on the spare anyway...
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
