| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1993
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 4x4
Used For: Daily Driver
Rep Power: 12 ![]() iTrader: (0)
I just thought of a weird way of bleeding your brakes. How about using you engine vacuum to bleed the brakes instead of a hand operated vacuum pump? you would still need to have a bottle in place to catch the fluid.
Caliper Bleeder---> Vacuum Bottle/Reservoir---> Intake Manifold. So the procedure would be fill up the master cylinder with fluid, attach all the hoses, start the engine and begin bleeding at the wheel... it seems like a cheap alternative to a power bleeder setup, and turns brake bleeding into a one man operation. the only thing i can think of is if the engine makes enough vacuum to suck out the fluid. Or possibly the other extreme, if the engine makes too much vacuum and sucks out the fluid too fast. Anyone done this before?
__________________
93 Ranger, 3.0L, 5spd, manual t-case swap, MSD ignition, 31x10.5 BFG AT's, 2006 ranger bucket seats, rancho RS500 shocks, Warn 37780 "Jeep" hubs, 2007 Glasstite Raven Canopy. http://www.cardomain.com/ride/2327329/1 |
Tweet
#2 |
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
Rep Power: 21 ![]() iTrader: (0)
What will that save you?
30 milliseconds? You don't need anywhere near that strong a vacuum source to attempt a vacuum bleed. You can't make any more than 30 inches or so of vacuum. Whether you do that with an engine or a hand pump is a matter of speed only. Use an engine and the technique will just drain your master cylinder and fail to actually bleed much more quickly. The reason vacuum bleeding fails has nothing to do with the speed of pumping. It's that an OPEN bleed screw doesn't hold vacuum off, and neither do the seals. Pressure bleeding actually works -- the leaky stuff is on the opposite end as the "business end." So does old-fashioned (pumping with the foot pedal) bleeding. Vacuum bleeding doesn't.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage. 1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles. 1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2. |
Tweet
#3 |
Year: 1993
Make: FORD
Model: RANGER
Engine: 3.0L
Class: 4x4
haha.. thanks for the reply. it was just a daydream i had at work, wondering if anyone had done that before.
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
