pugsly89bii
- Aug 1, 2008
Lots of torque and horsepower but how hard to stuff in a BII? The 351W is a tough fit.
Dave
351m & 400 are fantastic engines.They are the same as a 351c with just a taller deck height.These engines can easily make alot of HP & TQ with the right combonation.There is a book out that tells what to use and not to and gives a couple combo's for making power.I have rebuilt quite a few of these engines for trucks and have been impressed with the HP & TQ with just a milded RV type build. Dont let anyone talk you out of this engine as they are a good engine to build, just not very popular. Engine masters did one of these for compatition and won with it.![]()
ok. for all the doubters here is some stuff i found that might change(or blow) some minds!!!
http://www.popularhotrodding.com/en...2008_jegs_engine_masters_challenge/index.html
4 of the TOP 10 engines are 400's
The 400 is a good engine.
There is also little to NO aftermarket support for them
But it would be Uber cool to see what one would do in a BII. Just build it to be a 400, not a 351M. Like i said they use the same block, just diffrent crank and rods. So use the 400 rods and crank.
later,
Dustin
There is aftermarket support (excepting the pistons, which is THE most important step in correcting the 400's deficencies) And the 351M and 400 shared the same rods. The pistons were the difference between the two.
The 351M is a destroked 400 right? How do they make up stroke with a piston? Unless its taller or something on the 400.
later,
Dustin
