- Aug 6, 2007
- Age
- 45
- Puyallup, Wa
1972
So is there any way around having the cap pop and make a mess when you try to steer a ford with the engine not running?
Yes. Take your time.
Remove the cap and turn the steering through the window so you can see the level. Pause when it gets high.
Use the starter to turn the motor...
ya...if youd rather replace starters and solenoids instead of cleaning up some spilled atf.
my cap kept popping off during normal driving (system was at the proper level)...so i replaced the o-ring on the cap with a much fatter one. i have to use pliers to install/remove the cap now...but it doesnt pop off when i turn the wheels with the motor off. it does sometimes shoot a little fluid out of the little vent hole in the cap.
my cap pops off about 7000 rpm when i'm mud racing. It makes a mess so i made an adapter and clamped a hose to it and ran the hose to a recovery bottle
I did a search of the forum for the popping cap issue and this thread came up. I thought that I just wasn't putting it on right or maybe the cap was bad. Apparently not. So the only solutions are to put in an O-ring, use something else to secure the cap in place or add a vent hose? That's it? So what is causing the problem in the first place?
