Go Back   The Ranger Station Forums > Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 07-04-2009, 07:22 AM   #1
Jim Oaks
Building another truck
Jim Oaks's Avatar
Year: 1983 & 1996
Make: Ford
Model: Ranger
Engine: 5.0 / 4.0
Class: 4x4
Used For: Dedicated trail rig!
Jim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond repute
Default Need V-8 Swap Articles
Hey guys,
We need some V-8 swap articles for our tech library.
We need a write-up from someone who has done a swap on a 98+ and newer Ranger. We need both a 4.6 and 5.0 article with emphasis on wiring and any required conversion parts to help give our readers some guidance.
Thanks.
__________________
Some people are like slinkies -- not much good for anything, but they bring a smile to your face when pushed down the stairs.
Check out my Blue Oval Militia Profile HERE
Follow Me
Vote For TRS In Top 4x4 Sites
Jim Oaks is offline   Reply With Quote
Old 07-05-2009, 08:59 PM   #2
Mac
Premium Member
Mac's Avatar
Year: 2003
Make: Ford
Model: Ranger XLT Ext Cab
Engine: 3.0
Class: 2WD Street
Used For: Summer Beater
Mac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond reputeMac has a reputation beyond repute
Default
Jim,
There is a very good write up in the tech library on using the Explorer 5.0 motor in the later Rangers. It needs a little tweaking to explain maybe why that's the motor to use. Main problem I have seen is that the newcomers are not used to using the tech sections, usually it's all there. Maybe at the top of the V-8 section, in bold letters, CHECK HERE FIRST IF YOU HAVE A '98' AND NEWER RANGER and have that link there. GregR is the only one I know of that has done the 4.6 swap into a later Ranger.
Dave
Mac is offline   Reply With Quote
Old 07-10-2009, 11:56 PM   #3
Jim Oaks
Jim Oaks's Avatar
Year: 1983 & 1996
Make: Ford
Model: Ranger
Engine: 5.0 / 4.0
Class: 4x4
Default
Well, I put that article together, but we can always use more info. We don't have any 4.6 articles.
__________________
Follow Me
Old 07-11-2009, 09:36 PM   #4
TOPDOG2007
August 2010 STOTM
TOPDOG2007's Avatar
Year: 1996
Make: Ford
Model: Ranger
Engine: 5.0
Class: 2wd
Used For: Daily Driver
TOPDOG2007 is on a distinguished road
Default
I am interested in seeing more info on doing the 93-97 Ranger..Explorer 5.0 swap. Especially on wiring the factory explorer harness with the Ranger and why its supposed to be a nightmare.
TOPDOG2007 is offline   Reply With Quote
Old 07-13-2009, 01:19 PM   #5
TomB1269
TomB1269's Avatar
Year: 2002, 2005, & 2
Make: All Fords
Model: Ranger Edge '02, Freestar '06 & The newest '05 F150 FX4 SCrew
Engine: 3.0L/4.2L/5.4L3V
Class: 2WD/4x4
Used For: Original Daily Driver/New DD
TomB1269 is on a distinguished road
Default
Gents, I have scoward the net for OBDII V-8 swaps in the ranger, as I have an 02 and would love more power, and every thing seems to stop as soon as the Explore went 4.6. I have heard there are other streetable issues with the 4.6, as in Ford did not make a compact truck with one so it will not pass emissions due to the fact that the engine is not a OEM option in this class of vehicle, and you have to have model year or newer more, never mind PATS issues, ECM and cluster problems.
TomB1269 is offline   Reply With Quote
Old 07-20-2009, 09:40 PM   #6
jimmy3970
jimmy3970's Avatar
Year: 85
Make: ford
Model: ranger
Engine: 302 v8 5.0
Class: 2wd
Used For: Car Cruises & Car Shows
jimmy3970 is on a distinguished road
Send a message via Yahoo to jimmy3970
Default
I'm doing a v8 swap in my 85 ford ranger next month & I will show pix's when it is done.
jimmy3970 is offline   Reply With Quote
Old 07-24-2009, 02:01 AM   #7
MudSlanger
Junior Member
MudSlanger is on a distinguished road
Default
Ill probably have a fully detailed 5.0L swap forum posted probably in the next few months.
Im swapping a 99 explorer 5.0L 2wd auto in to my 00 ranger 3.0L 4wd auto.. I will be keeping my ranger transfer case so i dont have to build new driveshafts. There is also an adapter kit that will transform my 4R70W 2wd tranny into a 4wd that my ranger transfer case can bolt up to. No other modifications will be needed to my knowledge except having my exhaust redone and the PATS system reprogramed through the FORD dealership. Ill probably go ahead and buy the torque monster headers for better mpg's and a little more horses Other than that the motor will be pretty much stock. Ill be using the Explorer motor mounts since they will all fit in the ranger. The radiator part will probably give me the biggest issue as to I really dont know what kind i want yet. I heard the 4.0 ones are good BUT require modification.. 5.0L one works and i do believe thats a direct bolt in. dont quote me on that. Im retaining all emissions and AC because this will be my daily driver. Ive been doing a ton of research on this topic and pretty much i think i have it all down. Now im waiting on the guy to pull the motor and all the parts i need to make this swap work and ill be set.
Ill have plenty of pictures of the process.
The 99 explorer(8 cyl) and 00 ranger(6cyl) have a lot of similarities when it comes to electronics. Both vehicles use type B in the PATS system, also they both use a returnless fuel system, and both read vehicle speed through the VSS/ABS from the rear axle. So this swap should be fairly PLUG AND PLAY. I think i read somewhere ill need to adjust my wiring for the AC but ill figure that out once i get the motor running. Also have to swap a wire for the tach and pretty much should be the only thing ill have to mess with electrical wise. WHEW thank goodness lol
PS: Jim i bought that Advance Adapters 9 inch AOD to 1350 kit from this site to start things off Cant wait to get it and take lots of pics of it lol
MudSlanger is offline   Reply With Quote
Old 01-21-2010, 03:42 PM   #8
4.6stranger
4.6stranger's Avatar
Year: 1994
Make: ford
Model: ranger
Engine: 4.6
Used For: daily driving street fun
4.6stranger is on a distinguished road
Default
Any updates on the OBD II 4.6 swap? I swaped a 1996 OBD II mustang 4.6 and t-45 into a 1994 2wd Ranger I might be able to find some pictures and do a little write up if anyone is interested.
4.6stranger is offline   Reply With Quote
Old 02-05-2010, 12:17 PM   #9
onehotpocket
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0 SOHC
Class: 4x4
onehotpocket is on a distinguished road
Default
I'm actually inthe process of doing this right now. I have a 2000 ranger that had a 2.5 in it and a 351w out of a van that's going into it. I'll be sure to take pictures And let you guys know what sort of difficulties I run into. I know this isn't the exact explored swap you're thinking of, but ithink it'll be interesting none the less. I've yet to see some documentation of a 351w in a 98+ ranger.
thanks, Dave
onehotpocket is offline   Reply With Quote
Old 02-19-2010, 04:02 PM   #10
Spowerback
Banned
Spowerback's Avatar
Year: 2010
Make: FORD
Model: RANGER
Engine: v6 4.0L /
Class: 4x4
Used For: DD
Spowerback is an unknown quantity at this point
Default
302 cid or 351w 460 or later choice 342ci minus or v6 3.0L-4.0L bbk supercharged 8psi
Spowerback is offline   Reply With Quote
Old 02-19-2010, 07:00 PM   #11
chvlfrk
December 2010 STOTM Winner
chvlfrk's Avatar
Year: 1994
Make: Ranger XLT
Model: SB
Engine: V8
Class: 2WD Street
Used For: 5.0 huntin
chvlfrk will become famous soon enough
Send a message via AIM to chvlfrk Send a message via Yahoo to chvlfrk
Talking
I picked up a 99 last week, that is gonna be the new foundation for my RAT Ranger build, and I will take pics as usual.
__________________
ALL THROTTLE, NO BOTTLE!!!
Favorite quote: Elvira on Stroker Ace: "I like mechanics, they know how to tinker with things for hours, and makem go fast!"
TOY: Green 94 Pro Street
chvlfrk is offline   Reply With Quote
Old 03-31-2010, 04:56 PM   #12
DRAGONDOG
Year: 1997
Make: ford
Model: f150
DRAGONDOG is on a distinguished road
Default
i have a 97 f150 single cab long bed v6........this guy is gettin rid of his old beat up f150 with a 1990 305 in it (5.0 V8) i dnt know whatt yr his truck is if its a 90 or older.....my v6 blew a head gaskit so i already pulled it to do a overhaul on it.....will this 305 fit in my truck
DRAGONDOG is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
