diesel ranger
93prostreetranger
10+ Year Member
I have a 87 with the mitsubishi diesel in it. it does not have power at the fuel solenoid. cant find any wire diagrams. i did check the fuses under the dash non were blown. does anyone have any suggestions. Any is appreciated.
Thanks
are you having to kill it with 5th gear clutch dumps for now?
Frank
Sorry if I am misunderstanding or didnt read right but what is your question exactly, like is your fuel solenoid not getting power to allow the truck to run or to shut it off? If you need wiring diagrams your library should have Chilton manuals that should help you out.
No power to solenoid on injection pump, will not start. Also there is no diesel wiring diagram in the chiltons manual.
If I was in your position I would just run new wires to and from the soleniod and to whatever it needs to get it running. Theres only one desiel ranger running around town where I live so its great to hear theres another.
hey i got a 86 diesel ranger 6inch bds on 33 inch Xterrains not to many guys i come across with a diesel ranger go to the ford dealer ship with your vin and they will print you a complete diagram off
