| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
I jsut picked up a 92 3.0 auto that makes a odd whirring or whinning noise when u turn the key to run, if u dont wait till it stops the truck wont fire up or sometimes it wont start at all for a few. Its intermettent but its aggravating, it also has a rough idle but runs great anything above idle. Ive put a new coil on,fuel filter and fuel pump relay. Any ideas?
Tweet
#2 |
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
When you turn the key to Run, the fuel pump runs for 2 seconds to pressurize the system. Soounds like your pressure is bleeding off.
Try turning the key to Run two or three times before you crank it. If it starts reliably, you either have a bad fuel pump (it has an integral checkvalve that fails - very common), a seeping/leaking fuel line connection (fuel filter is a common place) or a stuck open/leaking fuel injector (not that common). I ALWAYS wait for the FP to run/stop before I crank, on everything I drive. Good habit with fuel injection. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
