Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Post New Thread Reply
Thread Tools Display Modes
Old 06-09-2009, 03:58 PM   #1
Cutter26
Junior Member
Cutter26's Avatar
Year: 1995
Make: Ford
Model: Ranger XLT
Cutter26 is on a distinguished road
Default Bearing wear
I have been getting a rubbing kind of sound from my right front only when turning left. First thing I thought was to change the bearings. I did that and the sound never went away. I just did the race, inner and outter. Still getting the sound. I noticed that my caliper has a little play in it. I was woundering if that could be causing the sound. Anyway, I took a couple pics of my spindle because it looks like my outter bearing is wearing a grove. I can't remeber if the spindle looked the way it does now the last time I had to take it apart. I don't know what the common wear on a spidle looks like. I took a couple pics.
Cutter26 is offline   Reply With Quote
Old 06-09-2009, 08:49 PM   #2
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
Unless there is a ridge you can feel by running your fingernail over it, nothing to worry about.
What am I seeing on the face of the part where the seal rides though? Is that all galled up from a blown bearing? or just grease on it?
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 06-12-2009, 01:33 AM   #3
pdmustgt
Junior Member
Year: 1999
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
pdmustgt is on a distinguished road
Default
Not to worry about it?
Signs of loose bearing plus after it wears in some you can tighten the inner nut all the way down will not be able to adju the bearings right. It don't take much wear to make it where you cannot adj them anymore.
pdmustgt is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
