Go Back   The Ranger Station Forums > Engine & Transmission Forums > Forced Induction
Notices
Forced Induction This forum is for ALL Turbo and Supercharger topics. This includes the 2.3L Turbo topics. Forum sponsored by Banshee Supercharger
Post New Thread Reply
Thread Tools Display Modes
Old 06-08-2009, 03:42 PM   #1
plsaville
Year: 2004
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Everyday Driving
plsaville is on a distinguished road
Default 1986 Thunderbird swap
Hay yall, so I am new to posting in these forums and am hoping you can help me out. I recently found a 1986 thunderbird with a 2.3 turbo; I current have a 96 ranger with the 2.3 as well. After I install the turbo and pipe everything in, does anyone know of any issues i will have? The main thing I am wondering about is my computer. Will the maf sensor be able to handle it or is there something else I will need to do? Look forward to hearing from you and thanks for any info you may have.
Phil
plsaville is offline   Reply With Quote
Old 06-08-2009, 06:36 PM   #2
red85
red85's Avatar
Year: 1985
Make: Ford
Model: Ranger
Engine: 306 ci
Class: 2WD Street
Used For: making noise and burning gas
red85 is on a distinguished road
Send a message via MSN to red85
Default
Check out the stickies in the forced induction forum. The pistons in your Ranger are cast and will not handle high boost. Max safe boost with those pistons is about 5 psi. As for the computer, if you have an EEC IV setup, it's just changing the pinout to match the TC computer. You'd be better off swapping all the TC stuff into the Ranger. It would be alot easier in the long run.
__________________
Professional Auto Service Tech
1996 Ranger XLT - 3.0 A4LD
1985 Ranger S - 306 ci/C4 (12.96 1/4)gone but not forgotten
1994 Ranger XL - 2.3T/M50D R1 (sadly retired now - Salt cancer got her)
2008 Ranger Sport - 3.0/M5OD R1
Don't ask a question if you don't want to hear the answer!
Putting brains before dollars since 1970
red85 is offline   Reply With Quote
Old 06-14-2009, 02:17 PM   #3
plsaville
Year: 2004
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
I found so good info on the other postings, but had a friend suggest swapping a computer out of a 89 mustang 2.3T. I would imaging there would be a little wiring involved. Does anyone know whether it will work or have any other ideas?
Thanks again for the help
Phil
Old 06-14-2009, 11:10 PM   #4
Bill G
Bill G's Avatar
Year: 1992 1984
Make: Ford
Model: Ranger 2wd Bronco II 4x4
Engine: 2.3, 2.8
Used For: Desert Tortoise habitat
Bill G is on a distinguished road
Default
If you have the entire car the easiest thing to do would be to swap all the turbo stuff into your Ranger. If you have money you could use your Ranger computer and get aSCT tuner for it. If you are just starting out I would suggest that you start with a stock turbo swap and then modify after you get it running.
Bill G is offline   Reply With Quote
Old 06-15-2009, 09:23 AM   #5
shadetree
shadetree's Avatar
Year: 1994
Make: Explorer Sport
Engine: 4.0
Class: 2WD
Used For: Work
shadetree is on a distinguished road
Default
No. The 96 is OBD-II and the computer connectors and wiring are entirely different. Changing the wiring from the t-bird and making it work would be a nightmare. It is best to use your existing MAF sensor. The t-bird is speed density, and doesn't work near as well.
You can use your existing computer and re-tune it. Check with Jess at www.rangersrevenge.com on how to do this.shady
Phil
The 89 Mustang did not have a turbo. Last Mustang with a turbo was early 87 in the SVO. They only had turbo's for 2 years in the Mustang, 85/87.shady
__________________
Bawney Fwank/Bobby Rush 2012.
shadetree is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
