WisdoM
I’ve got a clunk noise coming from the front end of my truck, I hear it mostly when I back up with the wheel turned to the right..it happens regardless if I’m breaking or not. Over the last few months I thought I had found what it was..first I found a bad radius arm bushing and replaced them both, found that my passenger side axle slip joint was so rusted and rotted it clunked so I replaced it and did the c clip eliminator, while I was replacing the axle I found a bad ball joint so I replaced them all, has all new u joints in the front as well. My brake pads didn’t have the anti rattle clips so I just installed those yesterday…the front end definitely feels better and has a lot less noises but the clunk is still there. I have checked all the nuts and bolts on the lift, coil retaining nut, pitman arm and tre’s . Its hard to narrow down but I think its in the driver side. Any suggestions on what else to check
