4.0 running really rough
99B4000_4x4
10+ Year Member
My truck started running really rough today and now is barely running at all. Went up to autozone and the codes said that both the O2 sensors were bad and were running lean. That code has been saying that for almost a year and the truck ran fine until now. Should I go ahead and replace the sensors or is their something else I need to check? Thanks
check fuel pressure if ur running lean u do not have enough fuel to the motor
injectors, sounds similar to the problem I was having
REPLACE FUEL FILTER
Test fuel pressure
Run injector cleaner.
bad injectors are about as common as honest politicians.
AD
Mass Airflow Sensor could also be a problem. If its dirty then the cpu gets the wrong airflow and ends up sending in the wrong fuel amount.
